'61 T-bird starting issues
Discussion in 'The Hokey Ass Message Board' started by WTFHemi, Feb 19, 2011.
  1. WTFHemi
    WTFHemi
    from Austin
    Ive replaced the solonoid, starter, and all cables on my '61 bird. still just getting the dreaded click. could the problem be in the swing away column or do i just need to replace the ignition switch next?
  2. 63Biscuit
    63Biscuit
    from Hudson, WI
    What kinda shape is the battery in? Are you getting full voltage to the starter solenoid?
    Everything I know about these cars suggests electrical stuff can be a real demon.
  3. ELpolacko
    ELpolacko
    Got the same issue with my 63. Lift up on the shift lever while trying to start and see if it starts.
    The shifter bushings wear with time and the neutral safety switch doesn't make full contact.
  4. wrenchn
    wrenchn
    from Chicago
    What happens if you jump the solonoid?
  5. x2 exactly! My dad had a 60 T-bird, and it was standard practice to pull up and toward you on the shift lever while starting.
  6. ditch
    ditch
    from boerne tx
    i hear there is a camp called "hot rod summer camp" try that they have a whole week dedicated to electricl gremlins , that may help! lotsa love , by the way its only $3000.00 a week. smokin deal!
  7. FiddyFour
    FiddyFour
    joined a lil over a year ago, and THAT is your best shot at a first post?
    ok. carry on
    its gittin dark :rolleyes:
  8. ditch
    ditch
    from boerne tx
    thanks post police , why don't you go out to the garage and learn your place! just givin a friend a hard time. carry on with your bad self.
  9. WTFHemi
    WTFHemi
    from Austin
    running new battery 15+ volts
  10. ditch
    ditch
    from boerne tx
    15 volts wow!
  11. WTFHemi
    WTFHemi
    from Austin
    yeah, but gotta buy the beer and ******s. it gets expensive fast
  12. WTFHemi
    WTFHemi
    from Austin
    thanks, i'll work that angle and see what happens..
  13. ditch
    ditch
    from boerne tx
    you have to get the post police , to make sure order is maintained! by the way get that car fixed and pronto!
  14. WTFHemi
    WTFHemi
    from Austin
    trying.. had a 4hr starter change out today..had to remove the drag link to get it out..too fing funny for me.
  15. Mr48chev
    Go back and check all of the battery cable connections especially the ground to the block. Make sure that the surface of the block where the cable end of it is s****ed clean so that the cable end makes good contact.
    Just about every time someone tells me "I've done this and I've replaced that and it still won't crank over". It's a connection or ground issue.
    You could also jump the starter solenoid or hood a remote starter switch to it to eliminate the wiring between the ignition switch and the solenoid.
    And the battery still may be suspect even though it shows 15 Volts which is actually a bit high as it should show about 12.5 to `12.75 fully charged. I would try a known good battery or have that one checked to make sure it is good.
  16. WTFHemi
    WTFHemi
    from Austin
    the only thing i havent checked is the ground straps. but that's next on the list. i cleaned all the contacts for the cables and applied dielectric grease to help in the connections.
  17. FiddyFour
    FiddyFour
    put the bong down and walk away... how ****in inbred ARE you?
  18. zman
    zman
    from Garner, NC
    Yep, both the 62 and 63 I have in the shop are the same way... I think you nailed it.
    Dude you deserve every bit of **** you get for that being your first post. You really need to Read This First! then do an intro here New to the H.A.M.B.? Introduce yourself here!
    Then you can get all snotty and whatnot.
  19. WTFHemi
    WTFHemi
    from Austin
    the guy is a friend and serious builder. he was bustin my balls.
  20. WTFHemi
    WTFHemi
    from Austin
    Looks like the shift bushings have it. I'll let everyone know if that covers it. Thanks for the help
  21. FiddyFour
    FiddyFour
    nah, the new guy is right. i was wrong and he called me on it.
    i'm going to go lay down by my dish now.
  22. zman
    zman
    from Garner, NC
    regardless he should read that and do an intro, then maybe we'll have a clue who he is instead of coming off like a putz...
    Sincerely
    the non-serious builder.
    :D
  23. zman
    zman
    from Garner, NC
    consider it theft prevention. if I don't tell people they can't seem to start either one.
  24. that feature and a pitt bull in the front seat, your golden:cool:
  25. badshifter
    badshifter
    If he's a friend he can bust your balls in private and not be such a **** in our house.
  26. zman
    zman
    from Garner, NC
    the other thing to keep in mind with having to pull the shifter to start, when you let it go it likes to drop into reverse. Just pay attention to letting it back down and not just dropping it.
  27. WTFHemi
    WTFHemi
    from Austin
    still cant get it to turn over regardless of how i manipulate the shift arm and column. i'm guessing i just need to byp*** the whole neutral safety switch. i'd rather have a car that starts in any gear than one that wont start in Park.
  28. pcterm2
    pcterm2
    thanks i was going to say something-you handled it
  29. 302GMC
    302GMC
    from Idaho
    Has anyone determined if this engine runs or turns over by hand ???
  30. WTFHemi
    WTFHemi
    from Austin
    car was running and driving great. been sitting for 2 weeks. so i changed all the items listed in the 1st couple of posts
