62 406 Galaxie questions
Discussion in 'The Hokey Ass Message Board' started by Judd, Nov 17, 2011.
  1. bigdav160
    bigdav160
    Real or not, I'd buy that car.
    It is swwweeet!
  2. mow too much
    mow too much
    I think most 406 and all 427 had cross bolt mains, so there should be bollt heads showing above the oil pan on both sides of the block (but some of the early 406 may not have them) I think.
  3. Fast67VelleN2O
    Fast67VelleN2O
    For 8k...... I would be running to get that.
  4. Bob37
    Bob37
    Only late 406s (1963) had cross-bolt blocks.Early ones (1962) did not. Looks like a fantastic deal from here!
    As Fast57F100 stated, it does appear to have the correct Kelsey-Hayes wheels. Although I tend to think most HAMB members are above this, you should close the deal on this car ASAP, because now that you put up pictures of the license plate someone could easily track it down and buy it out from under you. Just sayin'
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    I think that is well worth $8K. Looks very solid and being a red car makes it even more desirable. Aside from the valve covers it seems very stock and unmolested. Someone will grab this one if you snooze too long I fear. :) They ain't makin' 'em any more.
    Don
  6. Paulie9fingers
    Paulie9fingers
    Like has already been said, for $8K I'd be sittin' outside his house with the trailer waiting for him. Looks like a real nice car from the pics and $8K for a real 406 tri power car in that shape is cheap.
    If that thing was within 100 miles of me I'd be there this weekend to buy it even though I'm trying to sell stuff. LOL
  7. spike427
    spike427
    from Kentucky
    Car looks like it has alot of rust issues and previous patch work but still don't sound like a too bad of a deal if it's real but look at it close!
  8. mow too much
    mow too much
    How bad the rust issues are would be my main worry, but I love the 60's fords.
    I had a 63 1/2 405 horse 406 4-speed and several Starliners..........thats what I grew up with and it doesn't get any better for a Ford guy surrounded by a bunch of chevy lovers.:D:D
    I hope it works out for you.;)
  9. eberhama
    eberhama
    3spd w/overdrive was the base transmission. I know where there's a '62 406/6V equipped that way.
  10. Judd
    Judd
    Well it has all the correct casting numbers on block heads etc 2u63g****** vin number, trans code 5. so I bought it for $6,000. Lots of rust ,lower quarters behind rear wheels, front edge of hood, lower door skins. The interior is perfect other than the dash pad that shouldn't be there. The motor turns over but won't start, setting for ten years. Tires (LOL!!! setting for ten years LOL!!!). I think there is enough extra trim to do another car. Only 3 correct wheels the rears are wider. I was told it was 3.70 posi, ****ter shield with Zoom clutch plus I got the original bell housing. Floor and trunk pans look solid.
  11. SOHC427
    SOHC427
    Judd, there is a friend of mine here in Colorado, who could probably help with some sheet metal for your new prize....
    PM me for his number,
    Eric
  12. Judd
    Judd
    Thanks PMed Ya! I plan on keeping it original as I can, maybe ac under the dash I'm in south Mississippi and want to drive it regular and fix it to tow my Comet to the track. I'll start with getting it dependable and safe.
  13. MeanGene427
    MeanGene427
    from Napa
    I do have an original Ford underdash unit I'm not too attached to ;)
    Wouldn't work too well with the 427 and 5.14's in the 406 car, and the ragtop- well, y'know, what's the point of AC?
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    $6K............you did REAL good. When done it will be worth a lot more and not your everyday 390 car.
    Don
  15. Bob37
    Bob37
    That was a great deal! Lots of parts around for these cars. Good luck with it.
  16. Troublemaker427
    Troublemaker427
    Nice score. You got a deal for sure!!
  17. richie rebel
    richie rebel
    you my man is jesse james with out a gun, you stole the car,good luck with it.....richie...
  18. 65COMET
    65COMET
    Judd;I have a good friend that is a 62/63 Galaxy nut,he lives in the high desert here in CA.,let me know if I can help you find any parts!! 62 406,almost as cool as our Comets!! ROY.
  19. Judd
    Judd
    Finally got it off the trailer ( took 4 hours+) rear tag looks like 3.70 Trackloc T10 trans. 1989 tags, set more like 20 than 10 years.
  20. Judd
    Judd
    Two more questions. Can I use an old 352 distributor shaft to pre oil the motor before I start it and is the 406 fuel pump the same as a 390? Thanks again!
  21. FrozenMerc
    FrozenMerc
    The 352 distributor shaft should work fine to prime the pump. The fuel pump bolt pattern and lever arm will be the same, I don't know if the rated flow rates will be though. You should be able to use it to get it running though.
    Great score by the way. Have fun with that big old Gal.
    Good Luck
  22. Judd
    Judd
    Thanks!
  23. Judd
    Judd
    Well washed 150lbs of dust off it and put the street tires off the Comet on it to get it rolling. Swapped some valve covers that are closer to what should be on it.
    Hotdoggin DaddyO likes this.
  24. Bigcheese327
    Bigcheese327
  25. Jim Marlett
    Jim Marlett
    Makes me wish I still had mine.
  26. AnimalAin
    AnimalAin
    Very neat old car.
  27. MeanGene427
    MeanGene427
    from Napa
    Your new covers are the correct type, except for the chrome. I've heard rumors of chromed "dress up kit" covers, but the only round ones I've ever seen are the 427 "baldie" type with no lettering, that took the 427 flag decals. The round 406 decals are available, usually listed on epay. BTW, there have been debates, but both 406 decals should be to the left on the cover as you look at it, not both to the front of the car- drivers side to the front, p***enger to the rear
  28. boutlaw
    boutlaw
    Dang Judd, you did good, that thing is way cool, will look really good towing the Comet.
  29. outlaw256
    outlaw256
    im new to this old ford stuff but now that ive been driving my 62 for a couple yrs.i have fallin in love with these babies.i like your new car. ALOT!!!!!!!! meangenes cars send me over the top every time i look at them. and now yours.im thinking some of my other projects may just get pushed even far back.but the only reason i havent started on it is cause i love drivin this ol girl.i hate to tear it down.but to make her better i gotta bite the bullet. oh what to do? lol
  30. Judd
    Judd
    Thanks all! I put new tires and rebuilt the rear brakes today, waiting on front break parts, master cylinder and carb rebuild kits. It looks like the carbs are the originals c1ae9510-au + av. can't wait to get it running!! Any body have the wide trim piece for the drivers front fender? I have about 30 extra trim pieces and don't have the only one I need!! LOL.
