62-67 NOVA help
Discussion in 'The Hokey Ass Message Board' started by hotroddon, Feb 4, 2014.
  1. hotroddon
    hotroddon
    OK, I need a little help. Someone with an original V8 first gen Nova that doesn't have a frame stub or clip and has Stock Type motor mounts, I need a measurement from the top of the frame rails to the center if the crankshaft.
    If you can just lay a straight edge across the frame rails and measure up to the center of the crank bolt (taking into account the thickness of the straight edge) you will help me help a guy out.
    Thanks ;)
    PM me if you can help, or post the measurement here. Thanks
  2. landseaandair
    landseaandair
    from phoenix
    I've got 1/4" above the rails at the center of the crank bolt with solid motor mounts (no sag).
  3. landseaandair
    landseaandair
    from phoenix
    May want to compare with others though as there are at least a couple different part numbers for solid mounts and mine may differ slightly in height to the original mounts.
  4. hotroddon
    hotroddon
    Thanks - hopefully some others will chime in as well.
  5. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Very true^^^^^Moroso is one that comes to mind.Different measurements for solid mounts-from the same mfg.
  6. squirrel
    3/8 to the center of the crank hole in the timing cover....big block, mounts I made, using the stock trans crossmember and with the engine at the stock angle.
    sounds like 1/4" would be about right for a stock small block.
  7. hotroddon
    hotroddon
    Anyone else have a stock Small Block car?
  8. Down South Racer
    Down South Racer
    Early V-8 Chevy IIs had the engine offset one inch to the right.
  9. hotroddon
    hotroddon
    One last try for Help :)
  10. falcongeorge
    falcongeorge
    from BC
    Sorry, the motor is out of my car right now.
  11. Professor Fate.
    Professor Fate.
    I bet you would get a lot of help on Stevesnovasite.com
  12. hotroddon
    hotroddon
    Good Idea, I'll ask over there as well
