Projects 62 Bel Air Daily Driver Build
Discussion in 'The Hokey Ass Message Board' started by Shane Spencer, Sep 4, 2013.
  1. Shane Spencer
    Shane Spencer
    Will do, got an adj panhard coming. The d/s rear rubs so as soon as thats on ill pull it out of the shop for aome pics
  2. XERB
    XERB
    Excellent daily driver, cool cruiser, enjoy!
  3. Shane Spencer
    Shane Spencer
    Belairs back up on jack stands to ****on up the bottom end. Suspensions officially finished, tightened and loc***e on everything. Painted the exhaust, fenderwells and brake drums black. Also got the rear centered for good with the y bone and panhard bar adjusted properly ImageUploadedByH.A.M.B.1439796499.358994.jpg
  4. Shane Spencer
    Shane Spencer
    Rebuilt the carb. Somethings wrong and im not sure what, kind of a rookie when it comes to carbs. It starts hard unless u throw a little fuel down the carb. Itll run fairly smooth up around 1k rpm and higher but idles rough and wants to die around 700 rpm or lower. Also if you ease on the throttle itll build up rpm pretty smooth. If you stomp on it itll start to die right away. Seems to be starved for fuel. Everything in the carb is working well to my knowledge, any ideas? Any help is appreciated
  5. Shane Spencer
    Shane Spencer
    I shot carb cleaner around the carb base and intake manifold checking for vacuum leaks and got nothing so i think thats all good. The idle mixture adj screw on the carb still has no effect while adjusting it. I checked the screw opening and the hole in the base of the carb and everything looks clean and not clogged. Im gonna swap the plugs since its been sitting in storage while i worked on it for the past year and its been fired up repeatedly just to move it around the shop. Coil looks beat to, might swap that. Any other ideas guys ?
  6. Shane Spencer
    Shane Spencer
    Pulled the plugs, they look like hell from the hard starts in storage. Compression read right around 120 across all cylinders with a really weak battery. Im gonna tear into the ignition and re check my float level as well
  7. slammed
    slammed
    Tune it! Check alt too. Everything fresh & it should be driven highway speed to loosen up the old girl.
  8. Shane Spencer
    Shane Spencer
    Slammed the only thing that is confusing me is the idle mixture screw has no effect at all. I cant get it to idle below 900 rpm right now tho so maybe once i swap ignition parts everything will smooth out enough to tune it. Acc pump seems to work as fuel is shooting down the carb at all points of throttle. 3 of the plugs had no effect when i pulled the wires off while it was running. The other 3 started to kill the motor when i pulled em so i have an ignition problem for sure. Sound like a coil to you?
  9. slammed
    slammed
    Peace of mind. Research parts for quality. When the Ign./plugs/wires/coil/cap/points or Pertronix? connections/alt are known good-fresh then its time for that carb. And try not to let the stuff sit too long. Stuff today seems to go away faster that before when they sit still. Humidity. ****py gasoline. Sub par parts from God knows where. Last night the rebuilt alt was defect out of the box! Went back and had them test the next one right there....junk! Another.......junk! 3 in a row! Switched brands, tested bingo, good. Freakin'-A, today is a struggle.
  10. Shane Spencer
    Shane Spencer
    Coil was shot, swapped it out, re checked the points and threw new plugs in and it runs wayyyyy better. Got the idle squared away. Idles at 500rpm in drive and i dialed in the mixture screw so its silky smooth. Barely hear it runnin inside the car. Im still having what i believe is a acc pump issue. If you ease on the throttle or give medium load its fine. But if you stab it hard it falls flat on its face and then will pickup after that. Also has a slight popping sometimes as your building rpm easing on the throttle but its usually super smooth. I havent been able to drive it yet, hopefully tomorrow. Any suggestions? Im taking the carb back off regardless to double check everything
  11. Shane Spencer
    Shane Spencer
    Front ends back together. Have a guy coming tomorrow to do the windshield and back gl*** rubber. Bad news is i had an issue with the accuair ecu so thats on its way to california to get tested and hopefully replaced
  12. Shane Spencer
    Shane Spencer
    Windshield and back gl*** rubber is replaced. Can anyone recommend a good sealer to use ? Ive heard 3m is good stuff ImageUploadedByH.A.M.B.1441312631.671060.jpg
  13. bigpokie
    bigpokie
    It seems like the ecu's are problematic. I've heard it from a few builds.
  14. Shane Spencer
    Shane Spencer
    Yea the pin on the ecu for the power wire actually shorted and came out of the ecu and was stuck in the plug. Hopefully they send me a new one and ill be ready to go cruise [emoji41]
  15. Bruce A Lyke
    Bruce A Lyke
    Yes the 3-M stuff is good
  16. Shane Spencer
    Shane Spencer
    Good to hear 59nomad i ordered 2 tubes of the glazing and bedding compound from 3m. I also painted the wiper area under the vent panel black last week to clean it all up a bit ImageUploadedByH.A.M.B.1441848023.098958.jpg
  17. Bruce A Lyke
    Bruce A Lyke
    Yep, that is what i used after lots of searching on what to go with.
    You SB GTG
  18. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    hell yeah... nice 4 door....
  19. Shane Spencer
    Shane Spencer
    ImageUploadedByH.A.M.B.1442167406.625346.jpg ImageUploadedByH.A.M.B.1442167420.865936.jpg
    Took the car out for its first test drive last night. Hoping to have it wet sanded and buffed in the next few days
  20. oldrelics
    oldrelics
    from Calgary
    Very cool indeed, there were actually quite a few cool 4 doors in a local show this weekend, its good to see.
  21. Shane Spencer
    Shane Spencer
  22. Shane Spencer
    Shane Spencer
    ImageUploadedByH.A.M.B.1442338353.266732.jpg ImageUploadedByH.A.M.B.1442338432.084542.jpg ImageUploadedByH.A.M.B.1442338441.939808.jpg
    Started buffing. These pics are after the first cutting compound so its nowhere near as glossy as it will be when its done. Cant wait. Unfortunately i need to hit the roof with 1500 and 2000 again as there is a few wierd scratches in the roof that wont come out
  23. Shane Spencer
    Shane Spencer
    ImageUploadedByH.A.M.B.1444023879.030231.jpg ImageUploadedByH.A.M.B.1444023902.340881.jpg ImageUploadedByH.A.M.B.1444023917.496630.jpg ImageUploadedByH.A.M.B.1444023960.768291.jpg
    Still buffing. Had the car out n about a few times
    JeffCTN, brut4s, 62hotcat and 2 others like this.
  24. Bruce A Lyke
    Bruce A Lyke
    looks good, the buffing is paying off
  25. Shane Spencer
    Shane Spencer
    Been puttin miles on the car all week and daily driving it again. Im gonna take it out to the jalopyrama next week and itll be for sale by early november. Finally have an opportunity to build a 30-31 model a 5 window which is one of my dream cars. Shoot me a message if your interested in the bel air
  26. Shane Spencer
    Shane Spencer
    My buddy rob took some sweet pics of the car for me. It was actually pretty dirty when he shot it, turned out good tho. Its goin up for sale very shortly if anyones interested
    ImageUploadedByH.A.M.B.1445655017.194674.jpg ImageUploadedByH.A.M.B.1445655058.512074.jpg ImageUploadedByH.A.M.B.1445655076.389279.jpg ImageUploadedByH.A.M.B.1445655102.652661.jpg ImageUploadedByH.A.M.B.1445655117.076522.jpg ImageUploadedByH.A.M.B.1445655178.374776.jpg ImageUploadedByH.A.M.B.1445655199.764774.jpg ImageUploadedByH.A.M.B.1445655232.682036.jpg ImageUploadedByH.A.M.B.1445655251.744045.jpg ImageUploadedByH.A.M.B.1445655328.949278.jpg ImageUploadedByH.A.M.B.1445655341.642926.jpg
  27. oldrelics
    oldrelics
    from Calgary
  28. Shane Spencer
    Shane Spencer
    Well the car is gone fellas. Sold it a few weeks back. Lookin for a 51-53 poncho to daily drive now
