62 Buick motor ideas
Discussion in 'The Hokey Ass Message Board' started by duchan, Jan 14, 2011.
  1. duchan
    duchan
    from Antigo, WI
    I have a 1962 Buick special with a original v6 drive train, should I just leave it or I was thinking a small v8 like a 300 any suggestions
  2. smarg
    smarg
  3. They came with a 215, which is the same as a 300.
    The 300 does have a BOP bell, so thats easy.
    Also the 231 V6 is derived from the 215, so it would be a more modern alternative.
    I'd love to build a '61/'62 with the GN 3800 Turbo.
  4. texoutsider
    texoutsider
    from Frisco, Tx
    Want a 300 and a transmission...........trade me something for it........came out of a 66/67 Buick Skylark/Special
    Mark
  5. motorgod7
    motorgod7
    from chico,ca.
    I have a 300 4v, w/a th200 in my 62 SPECIAL. U will need a 215 LH exhaust manifold, port it to match the 300 ports. and it seems to me I had to grind the back corner of the block so it would fit. The big h***le it the cutting of the floor boards, and getting rid of the 2piece drive shaft. I used a th300 first, then switched to a th200 (it was free). The drive shaft tunnel is to shallow for a normal drive shaft also, maybe you could jack the car up, after you change out the rear end. Lets not forget a new ****** crossmember too. My transmission tunnel is sliced all over the place for every lil thing on the transmission, i.e. the governor, the vacuum modulator, etc. I had a small diameter driveshaft made and it rubs if I even think of having a p***enger in the car. When I decide to pull the car out of storage (tarped and in the bushes) It'l get a new ****** tunnel, and a 8in. ford rear end. If you go through with the swap, try to get a 64 buick 300 w/the alum heads and tell everyone its a 215.
  6. motorgod7
    motorgod7
    from chico,ca.
    It would be cool to add a turbo and EFI. Then again if your car has a manual ****** PM me with a price for your clutch pedals and everything else that go with it. lol, Terry
  7. joe_padavano
    joe_padavano
    Or, drop the 300 crank in the 215 block and save a hundred pounds.
  8. A Webly Vickers 348?
  9. Flat-Foot
    Flat-Foot
    from Locust NC
    I have the same car. My v6 runs great so I am leaving it for now. I may go for a 215 or 300 later on down the line.
    What are your plans for the car?
