Technical 62 C10 Drop
Discussion in 'The Hokey Ass Message Board' started by lowroder, Mar 4, 2020.
  1. lowroder
    lowroder
    So Im Looking To Drop My 62 C10. LWB
    It Is Currently A Torsion Bar Front.
    My Main Question Is How Low Can I Go In The Rear? Im Not Going To "C" notch It As Of Yet. Just Want A Decently Low Stance . An Im Also Going To Pull A Small 65 Camper With It. I Was Thinking 3 Or 4 In Rear But Not Sure If That Will Get Me To The White Wall.
    Also At What Drop Will I Need To Get A Adjustable Pan Bar. Some Say @4+
    When I Looked Under Truck Bed I Noticed The Pan Bar Mount Looks Like It Will Hit The Frame Brace Lower Then 4 .
    Any Details An Pics Of Your Drops Would Be Appreciated. Thank You .
  2. Penetrator
    Penetrator
    from SK CAN
    Why Does Every Word Need A Capital Letter?
    warbird1 likes this.
  3. Pinky was working overtime
  4. One Bad Pig
    One Bad Pig
    My 66 has leaf springs and I just flipped the axle. I think it was around a 5ish inch drop and I didn't do a notch. Yours sounds like the coil set up so I'm not sure about how the panhard bar will affect how low you can go. When pulling a trailer it did hit the bump stops a bit, but I have since swapped in an axle with a smaller housing and it's a lot better. Here is how low it sat with the added weight of the trailer on 275/60s 20190718_190739.jpg
    lowroder likes this.
  5. lowroder
    lowroder
    Just how my keyboard is set up.
  6. lowroder
    lowroder
    Mines stock now. On 235s.
    Just starting to fiqure my drop stance.
