62 comet 390 swap (NEED HELP)
Discussion in 'The Hokey Ass Message Board' started by 64fairlane, Feb 16, 2008.
  1. 64fairlane
    64fairlane
    im putting a 390 in a 62 comet and the center link hits the oil pan does anybody have a solution for this problem. thanks brian.
  2. yorgatron
    yorgatron
    straight axle.
  3. 64fairlane
    64fairlane
    yea trying to avoid going that route
  4. yorgatron
    yorgatron
    is your 390 front sump or rear sump? :confused:
    you might be able to swap another oil pan and oil pump.
  5. 64fairlane
    64fairlane
    front sump now rear sump would be real bad
  6. Malcolm
    Malcolm
    from Nebraska
    Throwing some ideas out here....
    Is your Comet front suspension similar to or the same as the early Mustangs? What about the Thunderbolt Fairlanes (I know Comet/Falcon are the same, maybe the Fairlane is similar)? Maybe you could check and see what they did in those cars to get the FE engine to fit. Wasn't it '67 or '68 when they started putting the 390 in the Mustangs?
    Any room to move the engine ahead a little? I can only imagine how tight of a fit a 390 would be in a Comet.
    Do you have any photos you can share with us? I'd be interested in seeing what you are up against.
    Malcolm
  7. gasser38
    gasser38
    Does it interfere too much to just notch the sump for clearance?
  8. sdluck
    sdluck
    Guys used to either notch the pan or weld a piece of tubing thru the pan for the centerlink,which means to pull the motor the left the pan in the car.
  9. 64fairlane
    64fairlane
    ill work on some pics yea its a hell of a squeeze but should be worth it...
  10. Dual sump oil pan? DIY oil pan?
  11. Kustom Komet
    Kustom Komet
    Still the 6 cyl steering, or did you swap to V8 steering? If 6, you can re-ream the pitman and idler arm and swap the drag link to the bottom. The V8 steering mounts lower, and may clear the 390 pan in stock form. '65 V8 steering is the best to use, works best with Granada disc brake spindles, and I hope you are at least using those to stop that combo.
    -KK
  12. texoutsider
    texoutsider
    from Frisco, Tx
    What did the 390 come out of?...........car, what year, truck, what year...what pan are you using now?.............many different variations.......Have you chopped the shock towers back ?........what mounts are you using?...
    M.
  13. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    notching the pan is probly the easiest route if you know a good welder..
  14. Mercury Kid
    Mercury Kid
    Man I really want to see some pics of this in progress and when it's done. As was said before, try mounting the center link under the arms and/or denting the pan.
  15. lostn51
    lostn51
    from Tennessee
    a big iron in a little car thats going to be one sick ride!!!!! take me with you on the maiden voyage PLEASE?!?!?!?!?
  16. Dirty2
    Dirty2
    I thought a 62 Comet was like a Falcon. I put a 289 in my 61 falcon and couldnt change the plugs very easy and your putting a 390 without an axle ? We need picts please .
  17. falconwagon62
    falconwagon62
  18. 6t5frlane
    6t5frlane
    from New York
    Try Crites.com
  19. texoutsider
    texoutsider
    from Frisco, Tx
    If you would respond to my questions, I can help you out.
    M.
  20. 64fairlane
    64fairlane
    the engine came out of a 70's f250 has same pan on it we are using the crites kit with the crites motor mounts and headers it has been in the car and does fit but its mighty tight the center link is the only issue i had the idea to move it the bottom by drilling out holes but we werent sure about the durability of drilling the hole out being the original hole is tapered?
  21. d2_willys
    d2_willys
    from Kansas
    u may want to see if there are any centerlinks that are dropped. Notching the pan is easy too.
