Rebuilding a 62 ford fairlane that was my moms in college. Decided to put a C4 in it and am having trouble tracking down the right flex plate and torque converter. Found some great info on the Hamb and other sites. Even found a part number but can't track one down. I found a 5 bolt bell housing, now I need a 23.1 oz flex plate and the right torque converter. Also what would be the proper tooth count for the flex plate. Any help is appreciated
Torque convertor will have the drain plug midway between the studs. C4 has two different size imput shafts so converter has to match imput shaft of transmission you are using.
