Projects 62 Falcon drive train decision.
Discussion in 'The Hokey Ass Message Board' started by Redneckpunk, Nov 2, 2024.
  1. Fordomatic
    17.5%
  2. 3 speed manual from Galaxy
    20.6%
  3. 200 big bell and c6 possibly turbo later.
    23.8%
  4. 5.0 HO drive train and suspension
    38.1%
  1. Kerrynzl
    Kerrynzl
    This ^^^^^ for the win!
    It'll make the car better ,more user friendly , and doesn't require butchering the tunnel etc. [except for the shifter]
    221 5bolt bellhousing V8? or the Aussie 221 six?
    The Aussie 221 six is basically a 200 six with a 1/2" taller deck height for the longer 3.46" stroke
    And a lot easier to swap than the 250 [with tall deck, wider oilpan, longer waterpump]
    Sharpone likes this.
  2. gimpyshotrods
    gimpyshotrods
    I did both.
    I have the old 6, and fuel injecton.
  3. gimpyshotrods
    gimpyshotrods
    Either one can work.
    I have a 1966 block, running an 8.5" clutch, with an adapter.
    It is the early pattern. Not partial V8.
    The later style can take a larger clutch, and may not require an adapter, depending on which T5.
    Sharpone and Truckdoctor Andy like this.
  4. Redneckpunk
    Redneckpunk
    Ok, that makes sense. I didn't realize one could find adapters, but where I have some of the later, I understand that i should be able to bolt straight on if I find a mustang t5 with bell housing and flywheel.
    My gut still pulls me toward the 200.
  5. Dave G in Gansevoort
    from Upstate NY
    200 with a T5. Some custom machining and fit some more carburetion on it.
    gimpyshotrods and Sharpone like this.
  6. Redneckpunk
    Redneckpunk
    The other piece of my indecision is that the 170 that is in the car now, just runs so nice. #2 cylinder had 149 psi, all others were 152/153 cranking.
    I can probably find a home for the 170 in my dad's stuff as we clean it up, but just not sure where.
    anthony myrick and Sharpone like this.
  7. Sharpone
    Sharpone
    A little off topic for your thread, you should list the slant sixes on the cl***ifieds here, they are cool little engines I’d give you more than s**** for them if they’re free turning and not to far away. I hate to see old engines s****ped.
    Dan
  8. Redneckpunk
    Redneckpunk
    So, I am new to this board, I will absolutely utilize the cl***ifieds on here as well as local cl***ifieds before the s****per comes. We have him lined up for next March/April.
    My dad sold 1 vehicle during his lifetime and recently p***ed away. My siblings and I went for a walk through the junkyard, and chose the things we wanted. There is some really cool stuff still available like a lot of V8s in the 360/390 era, and a ton from the 351/400 all the way back to the flatheads. Like you, I hate to see old stuff s****ped, but i can only keep so many without turning into him.
    There is so much stuff that the s**** man is planning to bring a baler on site when he comes.
  9. What region are you located?
  10. Sharpone
    Sharpone
    Sorry to hear about your dad.
    I’m guessing a lot of guys in this site would love to walk through your junk yard before the s****per gets turned loose. Good luck
    Dan
  11. Sharpone
    Sharpone
    Welcome to the HAMB
    Dan
  12. Redneckpunk
    Redneckpunk
    I'm in central Utah
  13. mrspeedyt
    mrspeedyt
    If the original engine is running good now I would simply rebuild the original transmission or swap in a bolt in stick.
    back in the early 70s a friend had a identical falcon as yours and I used to drive it a lot between South San Diego and LA when I was in the Navy. One day the flex plate cracked and I had to replace it. did the repair in one day ...
  14. chicken
    chicken
    from Kansas
    I've done the late 200/T5 swap into a '60 Falcon. I used an early 80's 200 for the "almost small block" bellhousing pattern (top two bolts are a tad lower than small block but not a problem), a T5 and bell from a Fox body , and an 8" Maverick rear. The 200 had flat top pistons, 10.5 compression using an early 200 head with small log intake for torque, a Carter YF carb from a 300 six, a neutral balance 302 flywheel and the clutch from the Fox body.(yes,it took some fiddling to make it fit properly). Had a nice small camshaft that was geared to low/mid torque and ran stock exh manifold with 2" single. That Falcon ran fantastic...pulled hard, cruised effortlessly with that T5 in OD and running a 2.79 rear gear. Yeah....1600 rpm at 60 mph uphill and down. Strong. Got 33 mpg on a 200 mile trip to the HAMB drags. Like a fool I sold it of course.
    mrspeedyt, gimpyshotrods and Sharpone like this.
  15. 1biggun
    1biggun
    If it were mine Id just fix the trans that's in it or buy a good used one that's the same.
    Second option is id install 302 ford a V8 and a OD trans depending on the gear ratio.
    What is the gearing now ? A OD will not help if its already geared high .
    3rd option is a SBC with 500 HP and a 9" rearend so its fast ;)
  16. Redneckpunk
    Redneckpunk
    Brakes are an absolute must no matter which way i go with this. After getting used to modern brakes they already make me nervous!
  17. Redneckpunk
    Redneckpunk
  18. chicken
    chicken
    from Kansas
    A '61 Galaxie won't have a 170. If it's a six I believe it'll be a 223, and no interchange of those parts with a 170 or a Falcon.
  19. Id rock that 170
    with a big ole grin
  20. Redneckpunk
    Redneckpunk
    Dang, You're right. Not sure why I had convinced myself of that.
  21. gimpyshotrods
    gimpyshotrods
    That is close enough to equal for a street cruiser.
    I'd just fix the minimum and drive it.
  22. Falcon with 4 lug slots today
  23. Redneckpunk
    Redneckpunk
    Sharpone and anthony myrick like this.
  24. 6sally6
    6sally6
    6sally6
  25. 6sally6
    6sally6
    ???? "Nasty 221 ...really.o_Oo_O
    6sally6
  26. 6sally6
    6sally6
    NEVER thought I'd suggest a sick cylinder for anybody but......the 200 (maybe stroked some?!)... T-5... 8" rear end with some gear (3.55:1) Some more cam(maybe alot more!) and extra carb....6 tube header...bump the CR to about 9.5/10:!...Aluminum flywheel...minimum of a dual bowl MC. Slam it to the ground(not really! but do lower it plenty !!
    Bring it to Myrtle Beach and gimme a ride !!!
    6sally6
  27. pprather
    pprather
    I'd take it to the local transmission shop to get fixed.
    Then drive and enjoy.
    It sounds like you have plenty of other projects to keep you busy.
    This car is nearly ready to drive.
    Sharpone and 1biggun like this.
  28. 1biggun
    1biggun
    Yeap I'd make it road worthy with what I had cherry it out as best as possable on a budget . So the brakes and make sure it's safe .
    Hoping up the original stock engine won't get you much and some high HP V8 on those brakes, suspension rearend is not great plan .
    You can spend say $1500 and make it a safe driver or go in debt up grading everthing on a free car .
    I'm sure there is a happy medium somewhere. I think it's cool stockish . boring but cool.
  29. 200 I6 with a T5. After you kick a rod into orbit with boost, you can throw the 5.0 in it easily.
    -Brent- and chicken like this.
  30. Redneckpunk
    Redneckpunk
    I ordered a rebuild kit for the Fordomatic. Like others mentioned, this way I can work on paint/interior while we drive and enjoy the car.
    SR100 and pprather like this.
