Projects 62 Falcon restoration if anyone cares.
Discussion in 'The Hokey Ass Message Board' started by steel rebel, Dec 7, 2011.
  1. steel rebel
    steel rebel
    Got the gas tank out (it's shot) I have a new one coming that I bought off of ebay. I was happy to see there wasn't much rust for a fifty year old car. I'll just acid etch it and spray undercoat.
    I tried starting it after changing oil. It hasn't run for a few years. The old fuel pump leaks and I was unable to get spark. The good news is it turns free. Before I try again I'll change the points. They were pretty corroded before I filed them.
  2. MAC50
    MAC50
    from Illinois
    [​IMG]Here is my 1960 Ranchero: For Sale
  3. patrick66
    patrick66
    Hmmmm...351W, narrowed 8", 3.90 gears...yeah, I can see that!
  4. BrokeDick
    BrokeDick
    from Idaho
    My 64, I bought it out of a alley a long time ago...
  5. Powerband
    Powerband
    Is that a Falcon?, My mom , grandma, and my uncle still in jail drove one when I was a kid...
  6. PinHead
    PinHead
    There's a guy here with one for pretty cheap, though I doubt you'd want to travel that far to get it. Otherwise just PM me.
  7. Bigcheese327
    Bigcheese327
    What is this? Falcons are chick cars.
    -Dave
  8. need louvers ?
    need louvers ?
    Damn, Chick cars?! Really? I didn't know that!!!
  9. 62rebel
    62rebel
    haven't you heard? chicks drive F150 King Ranch monstertrucks and Dodge Thunder Roads and VW Touaregs.
    i wanted a piece of **** sky blue Caddy but somebody beat me to it.
  10. Chaz
    Chaz
    I've owned more falcons (and econolines) than I care to count. They are a vehicle that really makes sense. Good luck with yours!
  11. Bigcheese327
    Bigcheese327
    And tailgate you. Don't forget that.
    It takes a big man to drive a small car.
    -Dave
  12. gary
    I started to say why in the world would you want to restore a falcon. Then I remembered that you already have some pretty sweet rion so a restration isn't going to be out of the question.
    I'm interesed. Its a cylinder falcon no doubt, 3 on the tree or fordomatic?
  13. Deadbird
    Deadbird
  14. steel rebel
    steel rebel
    Hey Porker
    It's an inline 6 cylinder stick. Three on the tree. I think 170 but I guess they made a 150. Thinkin maybe an overdrive if I can find one. I just wanted a little light cheap old car to tow behind our motor-home to spark some conversations when we stop. I found this solid little 4 door and couldn't p*** it up for $600. It's been stored under cover for about 15 years but the seller said he and some friends had it running a couple of years ago. I'm thinking a cheap Maco paint job and some seat covers and it's good to go.
    Gary
  15. mcnally351
    mcnally351
    from boston
    Cool car four door falcons make great cruisers.
  16. MrModelT
    MrModelT
    Ford offered a 144 ci 6-cylinder from the Falcon's introduction in 1960 until 1964, that averaged 90 hp. They also offered a 170 ci 6-cylinder (making 105 hp) introduced in 1961 and the 200 ci 6-cylinder (introduced in mid-1963) that made a good 120 hp.
    The early 200s can be identified by their 3 freeze plug/ 5 main bearing design. Starting in 1965, the 200 was re-designed with 7-main bearings.
    $600 was a GREAT buy :D
  17. steel rebel
    steel rebel
    We got brakes! Just got everything back together and thanks to my handy dandy vacuum bleeder the peddle is hard. Don't you love it when it gets hard? The brake peddle that is.
  18. 62rebel
    62rebel
    good little girl: "it's hard to be good."
    bad little girl: "it's got to be hard to be any good."
  19. 9310alloy
    9310alloy
    1961 144 cu.in auto...Falcons are great little cars with great gas milage, easy fix , how cheap and basic they were...kool
  20. lowko50
    lowko50
    Cool... Good Luck...
  21. Baron
    Baron
    Good luck with your Falcon. One of the guys in our club has a nice little 4 dr Falcon. Here is is at one of our "Sunday morning coffee" get togethers.
  22. steel rebel
    steel rebel
    You know I'm likin mine more all the time when I see what it could look like.
  23. steel rebel
    steel rebel
    It's a runner. Just needed a set of points. I guess just filing the old ones wasn't good enough. Can't believe how good it runs after 15 years with just one run a few years ago by the previous owner. The carb. was loose at the base. Probably from sitting and the gasket shrinking. No smoke and it Idled right down after a couple minutes of warm up. No bad noises and the fuel pump isn't leaking like it did when I first tried to start it a couple of days ago. Now I have two of them coming from ebay and one sitting on a shelf at Orileys that I ordered. Hope they will refund my money.
  24. need louvers ?
    need louvers ?
    Cool! Charging OK?
  25. steel rebel
    steel rebel
    Haven't hooked up the wires yet. Little threads are a kinda boogered. Haven't been able to start a nut. Thinking I might dig around and find some push on terminals. Think I might do that right now.
    Exhaust manifold is broken because someone didn't connect the bracket that keeps it from vibrating. But one thing at a time.
    Sorry threads are fine just had to find the right nuts.
  26. need louvers ?
    need louvers ?
    Got a couple manifolds in the stash around here too... Although the aftermarket has reproduced the '68 and later 2" outlet style that will make a large difference in H.P. for about 150.00 or so. Every bit helps with these cars. Sorry 'bout the threads, if I'd seen that I would have chased them for you.
  27. steel rebel
    steel rebel
    Charging.!!!!! The threads were good just had to find the right nuts.
    I'd like to buy one of those manifolds from you. Yes I did say buy this time. Give me a price. This is just going to be a putt around when we park our motor-home don't think I need a lot of h.p. If I want power I'll jump in my roadster.
    Gary
  28. Gary
    I think you afre headed in the right direction. Not a ton invested and a fun little hooptie.
  29. jazzfidelity
    jazzfidelity
    1960-63, the coolest Falcons, no thanks to McNamara, he just got lucky.. have fun!
  30. steel rebel
    steel rebel
    Thanks guys. I don't build show cars. I drive my cars. The roadster photographs well but it too is far from a show car. This little Falcon will serve it's purpose and after paint and upholstery which I will farm out I shouldn't have more than 3K in it.
