62 nova 2 4 bolt hubs
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 62nova2, Mar 7, 2011.
  1. 62nova2
    62nova2
    from Redwood NY
    i would like to convert my 4 bolt hub to a 5 bolt hub .does anyone no what year will fit ?????. i'm already waiting for a call from a salvage yard for a rearend (i beleive its coming out of a 65 nova2 )will the front hubs fit as well????? do i change the spindals as well ?????? Help :eek:
  2. This is the area to introduce yourself. Then post these questions in the general forum area.
  3. This page is for intros only.
    Do a proper introduction and then post your questions on the main board.
    Welcome from Michigan and good luck.
  4. I had a '64 Nova Wagon until last year. It was all original. It had 5 lug, 13" wheels front and rear. Bolt pattern was the normal 5 on 4 3/4 Chev. It had drum brakes all the way around. I'd consider changing to disk on the front. I believe that Fat Man and Chevy II Only both offer spindles (uprights) to convert to disk. Good luck.
  5. styleline
    styleline
    from so-hol
    welcome intro only
  6. theczking
    theczking
    64 through 67 are 5 bolt and all interchangable With a little machine work your front spindles will accept disc brackets ( my brackets and rotors came off an early le mans)
  7. novatattoo
    novatattoo
    from Canton,OH
    What he said. I have set off a 66 if you end up needing them. Send me a PM.
    later,Bill
  8. 62nova2
    62nova2
    from Redwood NY
    ok so thanks to every one for the help. sorry about posting this in the wrong place thought i was posting it in general discussion not at all familar with forums my appoligizes. so my name is bob i live in redwood ny i have a 62 nova and a 75 vw bug that i chopped the top on. thanks again to everyone
  9. styleline
    styleline
    from so-hol
    well bob welcome onboard
    cheers
  10. 40fordtudor
    40fordtudor
    another one.
  11. BOWTIE BROWN
    BOWTIE BROWN
