63 c10 front suspension swap
Discussion in 'The Hokey Ass Message Board' started by Marksp, Aug 15, 2012.
  1. Marksp
    Marksp
    Anyone know if the front suspension from a 71 will fit under my 63 c10? Plan to swap the whole suspension crossmember ***embly if it will fit. Thanks
  2. yumyumchoppers
    yumyumchoppers
    you have to elongate a hole on each side but other than that it will BOLT IN.
  3. Marksp
    Marksp
    Good news. Thanks
  4. VNTGE41
    VNTGE41
    from l.a.
    Yup the whole front crossmember and front suspension bolts in. Pretty sure 73-87 bolt in just gotta elongate a couple holes
  5. F&J
    F&J
    The 71/72 spindles are a bolt on, but you can do it the hard way instead, if you insist.
  6. johnod
    johnod
    Why would you want to do this?
    Seriously, whats the reasoning?
    I'm curious.
  7. disc brakes
    tk
  8. brokenspoke
    brokenspoke
    Check out 1947 to 1972 Chevy Truck message board
  9. gimpyshotrods
    gimpyshotrods
    You can get the disc rotors in 73-87 style, with six-lugs too, so you don't have to change the rear, if you don't want to.
    Could not find a direct link, but here is a vendor: http://www.earlycl***ic.com/catalog.aspx
    We just did a '65 C10 in the shop, last week.
  10. Marksp
    Marksp
    Five on five conversion and disk brakes for 100 bucks
  11. johnod
    johnod
    I did. Seems like a good board, thanks.
    Didn't see a thread about front end crossmember swap.
    Is there no simple way to just do a spindle swap ?
  12. brokenspoke
    brokenspoke
    On my 65 I just swaped the upper and lower control arms from a 1985 on the orginal crossmember
  13. MAD MIKE
    MAD MIKE
    from 94577
    Well you could, but you would still need to change the BJs to the correct units and futz about with tierods.
    The lower control arms have different bump stop heights for the later spindles, they are taller. The other thing is the later disc spindle is about an inch taller than the drum units. And that will require pulling out a couple of shims per FUCA stud to bring the camber back.
    There is a bit of conjecture on what swaps and what doesn't.
    FWIW on a '70 GMC 2500 8 lug drum, we used a '84 Suburban 2500 8 lug discs, control arms, spindles, and inner/outer tie rods. The center link is still the '70 piece. The '84 tie rods bolted to the centerlink. And a MC from a '70 Caprice with disc front brakes.
    With the installation of the disc brake spindles you will also need to change the MC to a disc type MC. You can find bolt on units, however the port configuration for using a later disc/drum MC is backwards, and the lines need to be flipped. Front to rear and rear to front.
    And if anyone tries to sell you an uber expensive MC for ~$200 tell em to go shove it.
    Usually it's just a '70 Corvette MC that can be picked up for ~$30 from Rock Auto.
    [​IMG] [​IMG]
  14. guthriesmith
    guthriesmith
    I haven't ever changed the crossmember to put 71/72 disk brakes on, just the spindles, ball joints, and the change to tie rods.
  15. Larry T
    Larry T
    I've done several this way for customers. Never hurts to put new ball joints in any suspension change anyway, right? I had the stock 5 lug rotors redrilled to 6 lug for one of the conversions where they wanted to run their original wheels.
    Usually end up putting in power steering too. REZ makes an adaptor.
