63 cadillac.....happy 1,000th post!
Discussion in 'The Hokey Ass Message Board' started by ryno, Mar 5, 2010.
  1. ryno
    ryno
    the sanding part really sucked, but yes they sure do look good when done!
    thanks, but dont let me stop you from using the same colors on yours
    i had to read this a few times to understand it!
    but now i get it.
    thanks
    and yes what goes around comes around.
  2. Sunshine14
    Sunshine14
    you nailed it, Im going for the same look with my 63
  3. ryno
    ryno
    So i finally got the tickin noise from the rear end taken care of.
    I replaced all the bearings and suspect it was a wheel bearing that singing to me back there.
    the 3rd member looked really good and so did the axles.
    Now to battle the oil pump issues!
  4. 193257
    193257
    Man Ryan that thing is looooooking good. It's just like Billy Gibbons said. Bad bad bad bad bad and nation wide. BTW Thanks for the offer for me and Marty to travel with you to the roundup but no way man. They won't even notice my old Riv next to the Caddy.
  5. ryno
    ryno
    I ve been having some oil pump issues lately now.
    i tore apart the pump and inspected the gears and pressure valve. everything looks really good. oil is supper clean, no metallic or anything funky.
    I was running 10 30 w oil and after talking with a old engine builder in the area, i decided to change out the oil and run some 20 w 50 with a new sending unit and wix filter.
    i don't have any engine bearing noise or lifter noise. only low pressure when i come to a stop and the idiot light will come on. as soon as you blip the gas it comes right back up.
    after changing the oil I'm at a steady 20-25 psi now and no light on.
    so far so good.
  6. ryno
    ryno
    pulled the fuel tank, gauge was not working.
    sender was messed up. i found a new one and in the mean time cleaned up the straps and vent tubes and re-painted them.
    ordered some new weather striping from ed, at weather striping specialist. waiting for the reveal scrapers to show. i got the roof rail and window ones done today.
    pics will be up later.....
  7. Grinder~deville
    Grinder~deville
    Awesome Caddi! I really like the smoothed out firewall. Do you have any pics of the process you went through on the cleaning up the firewall?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    What modifications were made to the heater system to make the firewall modifications possible?
  8. BEAR
    BEAR
    man thats a nice caddy
  9. holeshot
    holeshot
    from Waxahachie
    RYNO...1000 post's, your a sick puppy. but it is my style, and i can dig it DADDY O...POP.
  10. ryno
    ryno
    actually. no i don't. i kinda got caught up in the moment and didn't snap any. the only modifications , where to remove all that shit from the fire wall and removed all the parts inside the car also. i searched at my local o'reilly's and found a 3/4" heater hose that i believe is for a diesel. it was performed in the perfect shape to by pass the heater core. it ran from the back of the water pump to the cross over tube between the heads.
    thanks. i only took me 5 years to accomplish what you did in 5 months!
  11. THE_DUDE
    THE_DUDE
    Good lookin Cad man
  12. ryno
    ryno
    thanks.
    i got the fuel sender installed and re mounted the tank. made new sending wires and re-did the fuel lines.
    also pulled the carpet out and line-xed the floors. will add some pics later.
  13. ryno
    ryno
    got the underlayment and carpet installed, not crazy about the fit, but will deal with that after the round up!
    build the kick panels and installed the speakers.
    hopefully get to the center console tomorrow.
    also pulled the fuel tank, installed new sender and repainted.
  14. ryno
    ryno
    finished up the fiberglass center counsel.
    got all the interior cleaned up and installed.
    rebuilt the carb again. i think i found out the main problem. the accelerator pump is too big of a diameter. i need to find and original leather style assembly. the one that came in the cater kit was sticking after the bowl tapered.
    got all my weather striping done, finally from ed at weatherstripingspecilist.com
    hopefully be able to get some miles on the ol'girl before we head to the round up on Tuesday.
  15. cadillac nut
    cadillac nut
    very kool keeep up the good work.......
  16. ryno
    ryno
    ive logged about 70 miles on the ol girl yesterday.
    still have a bog that is driving me nuts.
    got my spares rounded up an dam ready to hit the open road south bound, austin tx!!
  17. Looks good, big daddy!:cool:
  18. ryno
    ryno
    thanks little buddy.
  19. ryno
    ryno
    made the round up trip no issuses.
    ran great 1200 plus miles
    12 mpg!
  20. BTB-Derby
    BTB-Derby
    Looks real sweet. A little different than when I saw it last year going out to Viva when we stoped by:cool::cool:
  21. ryno
    ryno
    yes sir.
    you guys down for the round up?
  22. BTB-Derby
    BTB-Derby
    You should see Tiger Mark, Diamond 49 & 1lowtrk down there. Just couldn't make it this year.:(:(
  23. jfrolka
    jfrolka
    are you gonna have the interior done up??
  24. jfrolka
    jfrolka
    my 64 had a problem with the fram oil filters... if you read the manual it should only have like 6 pounds of oil pressure at idle and like 35 under load... edelbrock 750 carbs really wake these engines up too.. also mine bitched until the 20w50 oil was in it as well, weird
  25. Mundae
    Mundae
    from San Diego
    Your Cad is done right. Thank you for running the Truespokes too. On the right car they look terrific.
  26. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
  27. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
    Dave?
  28. ryno
    ryno
  29. MIKE P.
    MIKE P.
    Beautiful Caddy!!!
