63 chev 327-what are power pack heads?
Discussion in 'The Hokey Ass Message Board' started by old man's '37, Jan 26, 2011.
  1. old man's '37
    old man's '37
    from Florida
    have a 63 327 factory four barrel engine and markings on the heads are a rectangle with a triangle. any help with the specs?
  2. jchav62
    jchav62
  3. davidbistolas
    davidbistolas
    Pull the valve cover please and post the casting numbers inside. rectangle and triangle don't tell us much.
    These are all camelhumps.
    These are powerpacks:
    but without the casting number I've nothing to look up.
  4. Rudebaker
    Rudebaker
    from Illinois
    You have a 250HP a327 and yes, it has the PowerPak heads. They have 1.72/1.5 valves and about 60cc chambers. A lot of people will tell you they are junk and to throw them on the scrap pile. I disagree, for a mild street build they are not that bad, especially if you want to maintain a stock or near stock appearance, great heads for even a fairly hot 283. The small runners and valves really boost low end mixture velocity and make the smaller cubes produce some low end TQ. In a light car with some gear they can be quite effective on the street and they really help a heavy automatic car with highway gears.
    A friend warmed over the original 250HP in his '64 SS by doing some mild port work, carb tuning on the stock 4GC and recurving the distributor. He slipped in a Summit 1103 cam and with the PG and 3.36 peg leg it would do a nice little burnout and had NO problem keeping up with traffic, he managed to beat a Trans Am with a TPI 350. The guy in the TA was surprised to say the least. He then swapped in a 200-4R and 3.73 posi which really gave it a kick in the butt, it runs pretty darn good for an old "sled". Traction with stock size tires has actually become an issue.
  5. gwarren007
    gwarren007
    Wouldn't the 416 casting 305 heads be a better fit for thier 58cc chamber, 1.84/1.5 valves and unleaded seats?
  6. davidbistolas
    davidbistolas
    I have a set of 416s on the shelf. For a 302/305/307- sure. a 327?... *maybe*... for anything larger they breathe like a 40 year 3 pack a day smoker.
