Technical 63 Chevy c10 2wd drive tranny swap T5
Discussion in 'The Hokey Ass Message Board' started by Schetk, Jun 10, 2024.
  1. Schetk
    Schetk
    from Stlouis
    Seems like a lot of different ideas on the internet.
    Asking if any one has done a swap from the granny 4speed to a t5.
    I have a 283 mild build, 3.73 rear gears , long bed 2 piece drive shaft.
    Mechanical speedo.
    Looks like I need to stay with a S10 83-88 for mechanical.
    im trying to figure out what I can use off current truck and what all I will need for the swap.
    I have a 1963 Chevy c10
    thank you
    me
  2. gimpyshotrods
    gimpyshotrods
    You will need a clutch disc of the correct diameter, that has splines that match the T5.
    You will either need a spacer to go between the transmission and bellhousing, or to do some surgery on the input shaft.
    The mounting bolt holes will need to be enlarged.
    Depending on what year your truck is, you may need a spacer ring for the center bore of the bellhousing.
    Truckdoctor Andy and Ken Smith like this.
  3. gimpyshotrods
    gimpyshotrods
  4. gimpyshotrods
    gimpyshotrods
    Your 283 should have a 168-tooth flywheel.
    This is a good one to replace the entire clutch assembly with fresh stuff, and to have the flywheel machined.
    If your truck is of the vintage that has side -mounts on the bellhousing, you must add a transmission crossmember under the tail of the T5.
    If you don't, you will break the case in short order.
    I am having an old-man moment on when those mounts stopped.
    bobss396 likes this.
  5. Schetk
    Schetk
    from Stlouis
    It's a 1963
  6. Schetk
    Schetk
    from Stlouis
    Thank you
  7. Schetk
    Schetk
    from Stlouis
  8. Schetk
    Schetk
    from Stlouis
  9. Gimpy, did the side mounts on the bellhousing disappear after the 1972 model year?
  10. Schetk
    Schetk
    from Stlouis
    Here is my bellhousing and mounting pics , can I use this? I have a 168 tooth IMG_1472.jpeg IMG_1471.jpeg IMG_1471.jpeg IMG_1472.jpeg IMG_1471.jpeg
  11. gimpyshotrods
    gimpyshotrods
    Truckdoctor Andy likes this.
  12. gimpyshotrods
    gimpyshotrods
    I think so.
  13. gimpyshotrods
    gimpyshotrods
    Measure the center hole in the bellhousing.
    If it is 5-1/8" you will need the ring.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If you haven't purchased a transmission yet, be aware that, generally speaking, the 4 cylinder S10s used a T5 with a 14 percent overdrive, while the V6 models had a 28 percent overdrive.
    anthony myrick likes this.
  15. Schetk
    Schetk
    from Stlouis
    Thanks, I have not purchased yet, I was looking for a .72 OD,
  16. Schetk
    Schetk
    from Stlouis
    Mine is 4-5/8, will I need to do anything?
    Thank you
  17. goldmountain
    goldmountain
    Make sure that it is a 5 speed. The T4 looks identical on the outside.
  18. Toms Dogs
    Toms Dogs
    from NJ
  19. gimpyshotrods
    gimpyshotrods
    Nope. No ring required!
  20. Mr48chev
    You should be safe with the 63 Bellhousing, The bigger bore for the bearing support came in 68 with the SM-465. The SM 420 has the same bearing collar od as car transmissions.
    The used to be 80.00 dollar swap of a Jeep T 5 ten spline input shaft solves the clutch disk issue.
    I think I got the last Astro Van clutch disk that fits my flathead that Rock auto sold to use with my S-10 T-5 This lets you use the oem Chevy clutch disk. https://lugnutz65chevystepside.weeb...ft-swap---diy-and-skip-the-adapter-plate.html
  21. gimpyshotrods
    gimpyshotrods
    Kinda.
    The T4 does not have the bump in the tail housing for 5th gear.
    This is a T4:
    Note the shape below the shifter box and ahead of the transmission mount.
    This is a T5:
    Note the difference in that same spot. The bulge is for 5th gear.
    firstinsteele likes this.
  22. Schetk
    Schetk
    from Stlouis
    Thanks
  23. gimpyshotrods
    gimpyshotrods
    Ultimately the metal tag or sticker tells the tale.
    GM was super sloppy when supplies got low, and when doing replacements under warranty.
    I've seen every mismatch possible.
  24. In_The_Pink
    In_The_Pink
  25. Use me as the SM420, SM465 like button... :cool::cool::cool:
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yeah, a lot of the metal tags I see around this part of the world are so obliterated that you'd have to call in the F.B.I. to try to acid etch the numbers like a handgun with the serial number ground off to read it.
