Technical 63 Comet Column Shift Collar Help
Discussion in 'Traditional Hot Rods' started by Dan Scholz, Nov 1, 2019.
  1. Dan Scholz
    Dan Scholz
    I have a 63 Comet with the 2spd Merc-o-Matic that was having some trouble with sliding between D and N so I figured I'd replace the shifter detent on the column. Well now the damn thing won't go back on right. Was hoping there's a trick I'm just missing to getting things lined up just right.
  2. Boneyard51
    Boneyard51
    Don’t know of any trick, I’ve replaced a lot over the years..... it’s just a matter of getting the right parts in right. Sorry I’m no help for you. Maybe pics might help. Always does.
    Bones
  3. Dan Scholz
    Dan Scholz
    Yeah, I feel like it should be just a case of pull it off and put it back but something's not sitting right with the shifter I think. Going to have to pull it all out again I be think.
    Boneyard51 likes this.
  4. Boneyard51
    Boneyard51
    Yep! You got it, just missed something, you’ll find it! Then that little light bulb will come on!
    Bones
  5. deathrowdave
    deathrowdave
    from NKy
    Well is been , years past , but I have attacked a few of these in my past . Just remembering what to do is the issue . “ I think my battery is goin Flat , Mate ! “ best as can recall there is a spring at the bottom of column that pushes up on the shift tube . The collar has a slot that must be aligned and push downward on the spring to reinstall the works back together .
  6. deathrowdave
    deathrowdave
    from NKy
    4EF3F2B6-2C94-45B4-8833-F82933D86AEB.png Here is the best as I can locate on a view of the guts to help you determine your answer .
  7. Dan Scholz
    Dan Scholz
    That must be what's not sitting correctly. It looks like the shifter ***embly just isn't meeting the shift detent right at all.
  8. deathrowdave
    deathrowdave
    from NKy
    Ok , just remember the sector (long shaft ) is not removable from the box as might thing . It goes all the way to the steering wheel from the box , the column is also known as the mast . If you look where the column is bolted to the dash there are two bolts and a clamp , the column will slide up and down to change the clearance between the shift collar and the wheel if you loosen these bolts . Retighten the bolts when you are finished and you should be good to go .
  9. Dan Scholz
    Dan Scholz
    Thanks! Hasn't even thought to adjust the column to get some additional clearance.
    One question, should the collar with the shifter stay in place when is all lined up, or should I have to keep putting pressure on it? Seems like it should lock into place but it isn't.
    Sent from my Pixel 3 using The H.A.M.B. mobile app
  10. deathrowdave
    deathrowdave
    from NKy
    It should stay in place as best as I can remember
