63 dynaflow front pump
Discussion in 'The Hokey Ass Message Board' started by westernrider70, Jan 6, 2014.
  1. westernrider70
    westernrider70
    from Monroe nc
    Is the 63 Buick Dynaflow front pump pressed on to the case? I have some old manuals for the 57 dynaflow and it shows bolts around the pump. But the 63 just has some lugs like it may be bolted from the inside. How do I get it off of the case. I purchased a front seal kit and want to replace the bearing behind the seal.
  2. amx180mph
    amx180mph
  3. saltflats
    saltflats
    from Missouri
    I took this out of the book if you can read it hope it helps.
  4. Baumi
    Baumi
    I had mine apart earlier this year. I think you have to unbolt the pump housing from the trans case, because the bolts that hold the pump together are going in from the back.
    1.Open and remove the converter, 2. remove bellhousing 3. remove valvebody 4. remove oilpump ***embly.
    I wouldn´t do it without a repair or shop manual, because you have to retighten the bands after ***embly. It´s not difficult, but a little guidance is good. I used my chilton and that was very helpful!
