Projects 63 f100 lowering
Discussion in 'The Hokey Ass Message Board' started by jwilcox, Mar 16, 2013.
  1. jwilcox
    jwilcox
    Hey guys, I just got a 63 f100 and I'm wondering what to do to get it so the rockers are about 4-5 inches off the ground. I'm 18 and don't have much money, so i can't just buy a mustang II front suspension setup for the thing. If at all possible I would like to just use the suspension on it and modify it, but I don't know these trucks so any help I can get is appreciated.
  2. oldnuts
    oldnuts
    from nebraska
    Droppedaxle.com and an axle flip with a c notch in the rear. You can remove leaves from the leaf packs also
  3. HOTRODPRIMER
    HOTRODPRIMER
    Lowering blocks on the rear,,possibly on the front. HRP
  4. jwilcox
    jwilcox
    Ok, and I know that you can reverse the eyes on the springs too. Would that help?
  5. derbydad276
    derbydad276
    good for about 2 inches instantly
    welcome aboard!
    use the search feature on threads there are several good lowering threads
    check out www.fordification.com great web site for ideas
    the new poor mans m2 suspension swap is installing a 2003 AND up crown vic front suspention
  6. The Big M
    The Big M
  7. willymakeit
    willymakeit
    Look at a jag xj6 also.
    I would drive it as is and save some money,make a plan on paper as to what you really want,then start acquiring parts.
  8. jwilcox
    jwilcox
    Thanks, and I did know that. I just need to cruise the junkyards to see if I can't find a spanked one for cheap. But that would be ideal.
  9. jwilcox
    jwilcox
    Hey, Thanks for the link this was EXACTLY what I was looking for. See the front was the part I knew would be tricky and this shows step by step what to do. Thanks again!
  10. The Big M
    The Big M
    This is good advice as well, especially if you feel there's a chance that you'd like to go lower in the future and add power brakes and steering. In that case a great option is an Industrial Ch***is Dakota kit, by the HAMB's own eLPolacko: http://www.industrialch***isinc.com/
    You can also find lots of info over at www.slick60s.com. :)
    Or there's a social group here on the HAMB for the 61-66 trucks: http://www.jalopyjournal.com/forum/group.php?groupid=173
  11. jwilcox
    jwilcox
    Yeah that's true, on the height issue I don't think I could have it any lower and be able to drive the thing, which is the objective. And I love the idea of going the old school hot rod route and using the original parts... and i'm sure after driving it some i'll want power steering and brakes, but that will come in the future. But I'm getting the truck for free so i don't want to put much money into it.
  12. lrs30
    lrs30
    from Kentucky
    I removed every other leaf from the spring pack on the front and it lowered it a good 3 to 4 inches. I would leave the first 2 in place then remover every other one. I tried to do the flip in the front but the axle ended up hitting the oil pan. I plan on doing a flip in the rear here soon. I have hear some saying it will not hit the bed bottom or frame rails but it all depends on how old and beat your sping PACk is. This is by far the cheapest route I have found, any semi truck garage should be able to make you new u bolts, I think the four I needed for the front was under $30. When I do the rear here in a week or so I will to a tech on it. Good luck hope it helps.
  13. jwilcox
    jwilcox
    That does help, Thanks. The oil pan dilemma is one that I'll have to figure out, but I'm going to pull the I6 in it and pop in either a vortec 4.3 out of an s10 or a 302 windsor , so I'm going to have to locate/ fab mounts for the motor anyways. And as for the back I figure I'll have to C-out the frame rails in the back to get it to be the right height. But again thanks for the advice, and I'd love to see how yours comes out
  14. BrownCow1992
    BrownCow1992
    from joliet il
    This thread was exactly what i was looking for i have a 63 f100 also and wanna lower it and this totally make sense on how to do everything thanks for the info!!!!
  15. jwilcox
    jwilcox
    Yeah and if you haven't yet check this thread out it goes through in good amount of detail on how to do the axle flip in the front and how to get it to work right.
    http://www.jalopyjournal.com/forum/s...d.php?t=531700
  16. daddio211
    daddio211
    BIGREDTODD's thread was exactly where I was going to point you to as well. And if you don't know, that's the very truck the Tim McMaster runs at Bonneville and Muroc at 140+ MPH, so it works VERY well.
    Sent from my DROID device using the TJJ mobile app
  17. JakeDW
    JakeDW
    from Missouri
    You want to do it cheap find an old camaro use the front stub flip the rear with blocks and a frame notch.
    I don't think you can get the rockers 4 inches off the ground with the stock straight axle good luck.
    Jake
  18. jwilcox
    jwilcox
    Yeah, I'm so glad that somebody brought it up, It's basically a step by step how to for these trucks. And it went that fast? wow, but it seems extremely well thought out
  19. derbydad276
    derbydad276
    you said 4.3 swap and s 10 in the same thread that can get ya killed in some parts of hamb
  20. jwilcox
    jwilcox
    Oh... I did not know that, I meant no disrespect to anyone, and hopefully no one got offended. The only reason I say that is that it's sitting in the yard so it's a rather low cost option
  21. daddio211
    daddio211
    There is nothing "traditional" about using S10 parts to build a hot rod, and many of us cringe at the thought.
    That doesn't mean you'll go to hot rod hell, but you'll catch plenty of flack here for it.
    S10 clips are better suited to "street rod" or "rat rod" builds in most cases. That's not to say you can't build a nice truck with S10 parts, but chances are it won't be well received here... especially with a 4.3 V6.
    To see how Todd and Tim's truck ended up (and current progress) follow this thread: http://www.jalopyjournal.com/forum/showthread.php?t=573420
    Don't worry, you haven't ruffled any feathers yet.
  22. jwilcox
    jwilcox
    Yeah, I'll agree that it is a little like going to a nice restaurant and just pouring ketchup on whatever you get. If I can we also have a 302/351, not sure which, that I would love to throw in it, but it may be used for something else. And if that 4.3 does go in it won't stay there long. But thanks for the heads up.
    And I have checked that thread out, that truck is SWEET!
