Projects 63 F100 unibody questions
Discussion in 'The Hokey Ass Message Board' started by forddork, Jul 24, 2008.
  1. forddork
    forddork
    a couple things.
    1. Does anyone know of anybody in WA that does drop axles? Or is there a good online source to buy an already dropped axle?
    2. Does anyone have any info on putting a mustang 9" dropout rearend in one of these truck?
    3. What is the easiest way to figure out which rearend I have? I'm not familiar with the older integral ford rearends like in this truck.
    Thanks in advance look forward to any info.
  2. synchro7
    synchro7
    I have a 63 short bed unibody also. Those trucks came with 9" rear ends from the factory. They used a big bearing, 28 spline axle, and the standard 9" dropout. I don't know for sure but I think the truck used a larger U-joint the a car.
    Hope this helps.
    wasp
  3. forddork
    forddork
    ive been under it and doesnt look to me that is is a drop out rear member theres no bolts on the front side of the axle housing
  4. synchro7
    synchro7
    It must have been swapped at one time or another. All 1/2 ton Ford PUs used a 9" rear from 1957 till 1972 with very few exceptions. Does it have 5 lug nuts or 8? If it has 8, it's a 3/4 ton, most likely a dana-60
  5. forddork
    forddork
    Its half ton I know that much bout rigs. lol. And I'm fairly sure its the factory rearend, it looks identical to the rearend in 65' F250 I just got for free.
  6. synchro7
    synchro7
    Looks like it has been swapped for a 73 or newer rear end. From 73 on Ford used the Dana-60 style (removable cover on the back side) in the 1/2 ton.
  7. junkyardjeff
    junkyardjeff
    Dana 44s have been used in 1/2 tons too. Jeff
  8. forddork
    forddork
    wouldnt a newer rearend also have the removable 3rd member, and why would my parts truck have an identical rearend. they both swapped?
  9. unibody
    unibody
    I have a 62 and it had a dana in it from the factory.
  10. forddork
    forddork
    what motor and trans does it have? could you tell me the axle code on the door tag?
  11. Tiger II
    Tiger II
    Maybe contact Dennis Carpenter.
  12. slddnmatt
    slddnmatt
    it could also be a dana 60-2 that is what my buddies had in it. dana 60 housing with smaller axles and 5 lug. jeep guys seem to like them
  13. ElPalacko here on the hamb will drop yours and ship it back to you when done. The were in the last couple months in rod and custom on the axle article.
