Projects '63 Falcon, and '39 Chev gassers
Discussion in 'The Hokey Ass Message Board' started by 1971BB427, Jun 19, 2013.
  1. seb fontana
    seb fontana
    from ct
    I have had issues like above but also caught in time to be able to go on done the road. Lucky, maybe but more so paying attention no doubt helped. Oh and while I think of I can't open any past pics, especially of the Falcon build. I'm sire I've seen them but a refresher to my old mind would be nice
  2. 1971BB427
    1971BB427
    from Oregon
    The issue of those past pictures disappearing was they were on Photobucket, and all of them disappeared when they held our pictures hostage for a huge fee. I closed my account, and lost them. I have all the images on a flash drive still, but haven't loaded them to my newer Imgur account.
    Here's a few I do have on my Imgur account. In no particular order.
  3. What is that seat out of? The one stored in the cargo area?
  4. 1971BB427
    1971BB427
    from Oregon
    The one sitting in the back of my '69 Suburban is the same seat as in other pictures; just after I had it recovered.
    They are mid 70's Mustang II buckets that I had headrests cut off, and padded, then new upholstery done. Once he finished them they had the right old school look for my g***er. Wish I could find more of them!
    Thor1 likes this.
  5. @1971BB427 , Thanks, looks like a good size and shape to suit a lot of cars.
  6. 1971BB427
    1971BB427
    from Oregon
    Yeah, a friend found them at the local Pick N Pull, and was going to use them in his '35 Plymouth coupe, but his brother wanted more modern buckets. I have a tough time finding old seats that aren't crazy prices. The last two sets I found that were OK came out of cars from the early 2000's and I did the same headrest removal, and reupholstering. I've purchased an old sewing machine, so able to do them myself now, and keep the cost down.
    The newer seats look decent, but I'm not fond of the plastic parts on them.
    Thor1 likes this.
  7. 1971BB427
    1971BB427
    from Oregon
    New front leaf springs, to raise the stance 2" in front. Reused my main leaf to make the swap easier, and just stacked the other 5 leafs under it. Longer 3/4 ton U bolts, but had to shorten them by 2" to keep them from hanging below the axle. The 1/2 ton U bolts were 1" too short. Reworked the shock mounts to raise the mounting point 2" higher, to avoid topping out.
    Changed my chrome s**** pedal to a Moon checkered aluminum pedal. Had to make a floor bracket, but it was a quick swap.
    Shadow Creek, Thor1 and impala4speed like this.
  8. 1971BB427
    1971BB427
    from Oregon
    Got the old '39 washed up and ready to head to Portland Transmission Sat. morning! Sure glad the weather cooperated, and suddenly turned fantastic!
  9. 1971BB427
    1971BB427
    from Oregon
    My friend who sold me the '39 project back in 2019 at the April swap meet gave me a copy of an article from the 50th Anniversary Portland Roadster Show. The article highlighted the Dukes Car Club display the club did for the 50th Anniversary.
    I looked over the 2 pages he copied and immediately spotted a '39 Chev coupe under construction in their display. I asked who it belonged to and he told me it was the same '39 he sold to me!
    Sitting beside the right front wheel ha said was the old 303 Olds engine with Tripower that was going into the '39 back then. After selling me the car he sold the engine to another friend. Always wondered what V8 had been in it before.
  10. 1971BB427
    1971BB427
    from Oregon
    A little sad update to the '39 Chev coupe. I stopped at a local grocery store on the way on Friday and was inside maybe 5-7 minutes. When I returned to my '39 I found someone had hit the p***enger side front fender! Put a good dent in the fender, but also hit it hard enough to crack the metal in two places, and bow the fender out on the side about center of the wheelwell opening! Of course no note, or anything left.
    It appears the vehicle that was parked nose to nose in an adjacent parking spot maybe thought they were in reverse and hit the gas to back out, but jumped forward instead? Pretty good hit, but not like they were moving fast enough to do major damage.
    So I'll put it away for now, and begin m***aging, and working the fender in hopes I can bring it back without removing it from the car. If not I'll take it completely off and work it out off the car.
    I ordered another quart of the same Wimbledon White paint, so once it's fixed I can either paint the whole fender, or blend it in.
    Couple pics of the damage to my fender. Took these after I pushed on the dent and popped it partially out.
    You can see where something black touched the fender above the dent. Looks like a bumper pad or some sort of black strip above the dented area?
    Chucky likes this.
  11. Chucky
    Chucky
    That ****s…
    RICH B, seb fontana and 1971BB427 like this.
  12. 1971BB427
    1971BB427
    from Oregon
    Sure does. But turned out it's not as bad as it looked at first.
    I took some time yesterday to look closer, and discovered the big crack wasn't the metal cracked. I had welded in fillers to eliminate the rectangle bumper bracket holes, and right behind that area is a fender brace to the frame. When the fender got hit the brace held the fender, and it bent right alongside the filler I welded in. So the cracked surface was the skim coat I put over my filler, not metal. Still going to need to be worked and repainted, but it's not going to need welding.
    The dent is another issue. I was carefully dollying it out from the backside yesterday and getting it almost invisible. But I didn't notice the fender had two screws that had once held the license plate bracket and someone ground them off on the outside, but left 1/8" of screw inside! I happened to hit one and it popped the paint on the outside. So it needs to get a small tack weld too, along with the little 1/2" long crack at the bottom of the fender. I knew there'd be paint work anyway, so just a little more now. Still hoping I can blend the new paint in, and wet sand and buff it so I wont need to paint the whole fender.
    Thor1 likes this.
  13. Mr48chev
    Dang, that ****s but at least it is fixable.
    1971BB427 likes this.
  14. 1971BB427
    1971BB427
    from Oregon
    The end of the car season isn't far ahead, and I've sort of neglected my old Austin g***er this year, so I'll drive it more as long as the weather holds. Put the '39 in the shop and begin the bodywork and paint the fender before the weather gets too cool.
    Thor1 likes this.
  15. 1971BB427
    1971BB427
    from Oregon
    Finally got the repairs done to the '39 front fender. Some dolly work, some welding of crack and an old hole for license plate that somebody filled with Bondo. Got the finish sanding done yesterday, and shot primer/filler on it.
    I've always thought flat panels were tough to work, but trying to shape a rounded panel like this fender, and ensure it matches the original shape is even tougher for me. I used my shape finder pin gauge to check the shape on the driver's side, and then held it against the p***enger side to check shape vertically and horizontally. It seems to be as close as possible and closer than my naked eye can tell.
    Of course now that it's ready to shoot paint the temps here are around 100 degrees for highs, and I don't want to try rushing to paint it early. So waiting until next week when highs will be low 80's and paint it then.
    Shadow Creek, Thor1, loudbang and 2 others like this.
  16. 1971BB427
    1971BB427
    from Oregon
    Shot paint on my '39 Chev coupe repair this morning! It was going great for about 4 coats.
    Then I gave it a couple more coats to use up the last of the paint I mixed up, and got a small sag in the paint. Not a huge deal, but means a little more wet sanding when I cut and buff it to blend it in.
    Thor1, loudbang and RICH B like this.
  17. 1971BB427
    1971BB427
    from Oregon
    I figured out why I don't do much painting! I bought the same exact paint from the same supplier I got the original paint from. But when I removed the masking tape I quickly discovered the latest batch isn't even close to the first! Much darker, and more yellowish than the original paint.
    If I knew what I was doing I'd have put a drop on the fender to check for a good match, but I wrongly ***umed it would be very close, and obviously it isn't!
    Already began wet sanding the whole fender when I stopped to take the picture. A friend had a new can of PPG acrylic enamel white for his Chev truck, so he let me have a small amount to tint my remaining paint and get it closer.
    I'm going to shoot the whole fender this 2nd time and hope it's a close match. I put a drop on to check and it looked good. Hope a half quart is enough to do it!
    Contacted TCP Global to ask about the color difference and they apologized and said different batches have "slight" differences. They asked for a picture of the difference, and I told them it was more than "slight".
    loudbang and Thor1 like this.
  18. 1971BB427
    1971BB427
    from Oregon
    Finally got the whole fender wet sanded, cut and buffed! Now this fender looks better than the rest of the car, so I'll pick up more 1500 grit paper and wet sand and buff the rest of the paint over the winter.
  19. 1971BB427
    1971BB427
    from Oregon
    I've always thought the old Lakewood 3 point rollbars were cool! I wanted one for my '40 Chev coupe back in 1968, but being a high school kid with a whopping $1.40 and hour job both the rollbar and shipping were well above my pay grade!
    So I started looking a couple years ago for a Lakewood rollbar and originals were asking $900 and shipping! New repros sold by a company back East were $1000 plus shipping! I decided to try and make one myself instead. I gave Marty Strode a call and asked if his tube bender would do the 135 degree internal bend, and he affirmed it would. He graciously allowed me to bring my tubing out to his shop this morning and he bent up my Lakewood copy as I helped with the dumb end of the project. Of course like everything Marty does it came out perfect!
    An original:
    What we bent up today:
    I need to make up the base plates, weld in the cross brace, and make up the removable back leg still. I'll paint it Lakewood red, and install a Lakewood sticker I have also to make it look period. Should be pretty easy now that it's bent up.
  20. DDDenny
    I've always liked that style of bolt-in roll bar, are you having Marty TIG weld it for you when you have it fitted, either way it should be a nice addition to your car.
    When I was in high school 1971 (ish) I was in the same pay grade as you I think, I wanted Lakewood traction bars on my 57 Chevy but did not have the coin so scrounged up the rect tubing and misc hardware and had a friend weld them up, painted them yellow, wanted them to look authentic so found some Lakewood logos in a magazine and glued them on.
    Turned out great, then snapped an axle.:mad:
  21. 1971BB427
    1971BB427
    from Oregon
    I wont take up anymore of Marty's time. He was generous to help me bend this up, so I'll mig weld the rest myself. I noticed on pictures of Lakewood bars that the back tube where the stub is welded to the hoop that some appear to have been ground smooth, or maybe some filler used? The finish there shows no welded surface where the stub meets the main hoop. The bases all show welds that aren't dressed.
    Thor1 and loudbang like this.
  22. 1971BB427
    1971BB427
    from Oregon
    I got the pieces Marty bent for me cut and welded not long after we finished them. But then I sat waiting on a break in the weather as my shop is small and I didn't want to paint the rollbar inside where my '39 is stored. But we got a rare summer day at 78 degrees yesterday, so I finished giving the rollbar a quick scuff with a Scotchbrite pad, and shot paint and primer on it.
    I left to make a hardware run, and came back about an hour later to what I thought would be a dry paint job, but got surprised by it being very tacky still! Not sure if I either shot paint too soon over primer, or if I got too many coats too soon, or if primer and paint didn't like each other? I let it sit outside in the sun for 3 more hours hoping it would cure, and fortunately it did finally dry!
    The color is rattle can Rustoleum Cherry Red, and a bit brighter than original Lakewood bars, but I really like it.
    Hopefully I'll get another good day soon and can back the car out into the driveway where I can tie the doors wide open, and be able to wrestle this into the back area without dinging it.
  23. DDDenny
    Paint is fickle as is Oregon weather and the forecast for later today looks like.................
    HAIL!!!:eek:
  24. earlymopar
    earlymopar
    Don't forget the potential 60 mph wind along with the hail. Of course Oregon "hail" is really "sleet" to most of the country east of the Rockies who get "real hail" that is golf ball sized and above.
  25. DDDenny
    All good as long as the hood of my pickup doesn't look like one big golf ball in the A.M.
    Hey Greg
  26. 1971BB427
    1971BB427
    from Oregon
    Weather cooperated, and turns out the coupe was sitting perfectly located in the shop to open my large 5 ft. side door and swing out of the way. So didn't even need to fire it up to get it into the car. All done, complete with Lakewood sticker too!
    50John, loudbang, Thor1 and 3 others like this.
  27. DDDenny
    Nice!
  28. earlymopar
    earlymopar
    Glad for you and all of us that what was forecast didn't happen Doug.!
  29. DDDenny
    Boy, they really got that one wrong didn't they!
  30. 1971BB427
    1971BB427
    from Oregon
    Got bare '39n Chev grille halves at the April swap meet at PIR, and took them to the local powder coater the next day. Hadn't heard anything since then so after a month I decided to just call and check on my grille work today. They told me it was ready last Friday, but shipping clerk forgot to call me. So went and picked it up this afternoon. They did a great job, and hope it looks even better on the '39. But it's going to have to wait awhile to install it. This Saturday is the annual Portland Transmission car cruise in, and weather is supposed to be wonderful! Then next week I'm gone for 5 days starting Wednesday for the antique gun show in Colorado. So sometime later this month I'll get to this.
    This is their "aluminum" powder coating with a gloss finish. Wont get a chance to put it in until later this month, but they did a great job for reasonable money.
    Shadow Creek, loudbang, Thor1 and 2 others like this.
