Projects 63 Falcon in the werx2
Discussion in 'The Hokey Ass Message Board' started by Karl_William, Nov 23, 2021.
  1. Karl_William
    Karl_William
    Is a straight axle g***er acceptable around here? That's the plan for this guy... FB_IMG_1637720604060.jpg FB_IMG_1637720598514.jpg FB_IMG_1637720594835.jpg FB_IMG_1637720589902.jpg
    VANDENPLAS and hotrodjack33 like this.
  2. oldiron 440
    oldiron 440
    Should be interesting, I've never seen a four door Falcon g***er....
  3. 41rodderz
    41rodderz
    from Oregon
    You will be flamed, turned over the hot coals and brow beaten forthwith in 1,2,3 …. :D Do you that’s all I am going to say .
    Budget36 likes this.
  4. 41rodderz
    41rodderz
    from Oregon
    One last thing. Read the Shoebox Ford g***er thread .
  5. Karl_William
    Karl_William
    Ha, just got done with it. So what can a guy do to gain approval here? Really.
    hotrodjack33 likes this.
  6. hotrodjack33
    hotrodjack33
    Well, I APPROVE. A lowly , beat up 6 cyl. 4 door Falcon...not the most desirable of cars...makes it the perfect candidate. Unibody car so probably a full frame, and not just a stub for the front axle. Weld up the rear doors...instant 2 door. Go for it.
    6inarow and lothiandon1940 like this.
  7. go for it. the tiny wheel wells are just crying out for some fat tires. and those back doors will make radiusing the rear wells really easy. Building a car for HAMB approval will get you sainthood around here. Just remember, always ask for approval first. Just keep in mind who you'll be building it for and you'll be ok.
    6inarow, 41rodderz and hotrodjack33 like this.
  8. RmK57
    RmK57
    If there's one vehicle on this planet that's worthy of a sbc swap this is it.
  9. hotrodjack33
    hotrodjack33
    A small block CHEVY?:eek::mad::eek::mad:
    That baby needs a big block FORD!!!!!
  10. twenty8
    twenty8
    This one might fly.
    I'm with you, Jack..............:)
  11. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Your car and your money, hope you got lots of it!
    hotrodjack33 and 6inarow like this.
  12. 41rodderz
    41rodderz
    from Oregon
    Let the naysayers comments go in one ear and out the other. Build it out how you envision it. Build it so it keeps you safe
  13. 41rodderz
    41rodderz
    from Oregon
    Straight axle, check . What are the details in you build plan ? Oh yeah, just show and talk about parts you are running that relates to 1965 or earlier.
  14. deathrowdave
    deathrowdave
    from NKy
    Build it as you like , drive it like you stole it , and smile like a possum eating **** !
    6inarow, hotrodjack33 and Budget36 like this.
  15. Budget36
    Budget36
    Wasn’t but a month or two ago another member was at the starting point of a similar year Falcon and going the g***er route. There was some good info in the thread about beefing things up.
  16. Anderson
    Anderson
    Why do you so desperately seek approval from a group which does not approve?
    twenty8, Tman, WiredSpider and 4 others like this.
  17. guthriesmith
    guthriesmith
    Is werx the same as works? o_O
    little red 50, twenty8, X38 and 3 others like this.
  18. J. A. Miller
    J. A. Miller
    from Central NY
    Only if it's spelled workz.:rolleyes:
  19. F-ONE
    F-ONE
    from Alabama
    Honestly, the perfect "G***er" candidate.
    It's a light car.
    It's a piece of junk. (they were pieces of junk new much like the later M car they preceded) I like them I guess.
    The engines, suspensions on these are pretty much junk unless you are running the small 6. It's a blank slate.
    Karl_William and hotrodjack33 like this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Go for it! HRP
  21. hotrodjack33
    hotrodjack33
    Because some of us are more sensitive...and in touch with our feelings:eek:
  22. rpu28
    rpu28
    from Austin
    Karl, you might fit in better here if you drop a flathead in the Falcon and take about five inches off the lid. Plus, you'd stand out at any car show.
  23. goldmountain
    goldmountain
    Lower it and make a custom out of it.
  24. Last edited: Nov 24, 2021
  25. 1971BB427
    1971BB427
    from Oregon
    They don't need a full frame, or even a stub, unless the plan is for big power. An engine making under 400 hp will not be an issue in these early Falcon unibody frames. But if the plan is for a big block with lots of torque and HP, then by all means it needs a lot of frame work.
    I built a BBC 468 in my falcon g***er, with a Super T10 four speed, and 8.8" Ford posi. Not only did I do a lot of frame work, but I also did a full cage and firewall supports out to the ends of the frame rails.
    I personally wouldn't build a 4 dr. Falcon, but I'm an old dinosaur that thinks it's a lot of time, work, and money wasted on a 4dr. that wont ever be returned if I sold it. So I'd wait for a similar 2 dr. as they're still not that expensive in similar condition to this 4 dr.
  26. Karl_William
    Karl_William
    Love that!
  27. Karl_William
    Karl_William
    Well I DO just happen to have a somewhat built flatty!
  28. Karl_William
    Karl_William
    I've already tossed around the idea of s****ping my other project and using the flathead.
  29. Karl_William
    Karl_William
    8BA with **** 264 rotating ***y, offenhauser super dual intake, Edelbrock 94 carbs, Potvin super 3/8 cam ground by Schneider racing cams, Edelbrock heads...
  30. Karl_William
    Karl_William
    Nice selfie!
    hotrodjack33 and Randall like this.
