Technical '63 falcon mileage
Discussion in 'The Hokey Ass Message Board' started by evilhorde, Feb 23, 2022.
  1. sunbeam
    sunbeam
    The motor and trans were from a 62 Fairlane 221 with 3 speed no overdrive running a 9 inch with 3.56 gears A swap from the Autolite 2100 to a AFB 2800S was worth 4 mpg.
  2. evilhorde
    evilhorde
    With fresh plugs and wires I'm now getting 22.5 mpg, still not achieving '63 falcon numbers but comfortably cruising at 65mph.
  3. Beanscoot
    Beanscoot
    Canadian gallon or US gallon?
  4. evilhorde
    evilhorde
    A Canadian gallon? We're metric up here friend, i converted it all to US gallons and miles in an attempt to make sense to y'all. My car is getting 9.565 Km/L
    Edit: whoops i see that you're up here too. Canadian gallons? what's that aboot, eh?
    Budget36 likes this.
  5. moparboy440
    moparboy440
    from Finland
    There's 0.86 Imperial Gallons (the Canadian gallon) in a US gallon.
  6. dan c
    dan c
    falcons with the 144 probably would do near that.
    jimmy six likes this.
  7. gimpyshotrods
    gimpyshotrods
    Mine did.
    dan c and jimmy six like this.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I don't see why if your doing 50-55 mph that the falcon couldn't pull a 30 mpg p***. Its gutless engine topped out at 65 I think going downhill..... Freeway speed limits here in Texas were 55 for a LONG time....A stock model a banger can get mid 20s in fuel economy... Probably as safe as a falcon anyways but cooler.
  9. sunbeam
    sunbeam
    I had my 60 Falcon when Kansas speed limit was 70 day 60 night It was adequate at highway speeds 70 mph it was a at 2800 rpm but remember a 144 only had a 2 1/2 stroke.
    gimpyshotrods and seb fontana like this.
  10. gimpyshotrods
    gimpyshotrods
    Amazing how much speculation continues here, even after present and former Falcon owners have already spoken up.
    arkiehotrods likes this.
  11. ronzmtrwrx
    ronzmtrwrx
    A close friend of mine’s dad bought a new 1960 falcon, two door, 6 cyl, 3 on the tree, 13” wheels, with a radio, heater, and a rubber mat. He was a route salesman for a meat packing plant, making 20-25 stops per day. He kept track of his gas mileage religiously and his little car got 26 mpg. Now we are a rural area and it’s pretty flat terrain around here so I’m sure that helped. Anyway, he got paid mileage from the company and that little car paid for itself in 2 years. He then bought a new 62, and then later a new 64. They all performed pretty much the same.
  12. gimpyshotrods
    gimpyshotrods
    Mine got 24-25 in the city, and in our copious traffic. The low 30's were steady-state on the freeway, only stopping for fuel.
    3.56:1 gears, 13" wheels.
    jimmy six and ronzmtrwrx like this.
  13. sunbeam
    sunbeam
    One thing to remember was the lack of traffic in the 60s less slowing down and speeding up there are many roads today you cant use cruise.
  14. I had a 60 four door.
    Bone stock when I got it except the previous owner had replaced the 144 with 200.
    Still used the 2.77 three on the tree and 3.10 rear with 6.00 X 13s.
    It would get a solid 26 if I kept my foot out of it...which wasn't that often. :D
  15. ken bogren
    ken bogren
    <<< My 63 with a 170 can keep up on the freeway at 65 - 70 without getting run over by a Prius. The 170 is a little weak and needs a tweak so mileage isn't great, I'm guess 17 - 18, I don't drive it enough that mileage matters.
  16. 4 pedals
    4 pedals
    from Nor Cal
    There was a 62 Meteor wagon for sale near me recently that claimed to have the 177 and 3 on the tree. I thought bout picking it up for a day or two for a daily driver, but ultimately was too slow and it already sold.
    Devin
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It wasn't a Falcon, but around twenty years ago, I had a '64 Pontiac Tempest two door, 215 cubic inch six and a three speed with a 3.08 rear. No options to speak of, other that seat belts and a day/night mirror. I tuned it, rebuilt the carb, jacked up the initial timing setting about 6 degrees over stock, and it got 24.7 mpg on the open road. 19 in town.
    Roothawg likes this.
  18. Falcons are pretty light but not aerodynamic. I forget the name of the engine efficiency curve. As I understood it from ecomodders.com, the fuel mileage goal would be to keep the engine in the sweet spots of the efficiency curve. For stop-and-go driving that was generally said to be pressing the pedal down and getting to cruising speed fairly quickly because of the fact that gasoline engines are throttled is a significant inefficiency.
    I never felt like I really understood the engine conditions for freeway cruise speed. You want the engine in a sweet spot, maybe with the engine rotating slower. I'm wondering how the throttle (****erfly/ies) position figures into it. I want to say that it was a given that the efficiency ****ed because of throttling. Anyone know? And know how to read the brake specific fuel consumption (I think) curve/chart?
    I believe the best strategy is reducing aerodynamic drag. And using an electric motor because they're generally much more efficient. And they reduce emissions.
  19. jimmy six
    jimmy six
    They were economy cars and I knew many that got 30 mpg on steady hyway driving 60-65. Of the 3 US the Falcon was the best.
    gimpyshotrods likes this.
