Technical 63 falcon WAGON wheel cylinders
Discussion in 'The Hokey Ass Message Board' started by NolanRyanLady, Mar 11, 2018.
  1. NolanRyanLady
    NolanRyanLady
    I looked through the forum and haven't found an answer.
    As far as wheel cylinders go, has anyone done them? We got new cylinders from Oreillys and they are smaller .***uming they gave us ones for a regular falcon. Finding different measurements for wagons.. trying to figure the right direction to go.. Bore.. Thread size?
    It's a 1963 Falcon wagon v8. 10 inch front drum brakes. 9 inch rears.
    NielsK and chryslerfan55 like this.
  2. sunbeam
    sunbeam
    There are 15/16 and 13/16 wheel cylinders for 63 falcons. Wagner numbers for 15/16 cylinders are wc59240 and wc59241.
  3. NolanRyanLady
    NolanRyanLady
    Regular falcon or falcon wagon? The wagons are 5 lug.
  4. NolanRyanLady
    NolanRyanLady
    The ones we have are too small.
  5. NolanRyanLady
    NolanRyanLady
    Thinking maybe 63 Fairlane front cylinders may work based on measurements?
    We tried looking up 63 rancheros front wheel cylinders and it doesn't even list them or give an option. We have drum brakes .
  6. HOTRODPRIMER
    HOTRODPRIMER
    Is the car a 6 cylinder/4 lug bolt pattern? HRP
  7. Could it be that V8's have the 5 lug and 6cyl have 4 lug, you just have a V8 wagon. A buddy of mine has a '61 6cyl wagon and it has the 4 lug wheels.
    By the way, how rare is a V8 wagon?
  8. NolanRyanLady
    NolanRyanLady
    It's originally 260 v8. 5 lug.
    They only made 2400 two door wagons
    Mine is a v8 2 door. Which I'm ***uming they only did about half that. The wagons with the v8 were technically 63 1/2 year.
  9. NolanRyanLady
    NolanRyanLady
  10. Reman
    Reman
    from Florida
    Yes, the Falcons all have 5 lugs on V8 cars and 4 lugs on 6 cyl cars.
  11. sunbeam
    sunbeam
    From a parts book the 15/16 wheel cylinders are rights and lefts and the 13/16 ones fit ether side Look at your old ones and see if they are alike or different from side to side.
  12. NolanRyanLady
    NolanRyanLady
    Found the right ones online. They say bore size is 1 1/8th?
    Same as 63 fairlane?
  13. NolanRyanLady
    NolanRyanLady
  14. V8 Bob
    V8 Bob
    My Bendix info states the '63 V8 Falcon wagon should have 10" drums front and rear. Can't find any Falcons (or other fords) with 10" fronts and 9" rears.
    Correct rear wheel cylinders for your wagon are 29/32". 1 1/8" are the front cylinders, not rear.
  15. NolanRyanLady
    NolanRyanLady
    Update. Found them at Oreillys. The rears part number is
    WC59240
    WC59241
    Fronts were
    WC40951
    WC40952
    Same fit as a 63 fairlane 500.
  16. NolanRyanLady
    NolanRyanLady
    They are 10" all the way around. You're right.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Having all the information makes a world of difference. HRP
  18. V8 Bob
    V8 Bob
    My book states 1 3/32" front, 29/32" rear for all '63-'64 Fairlane p***enger, and 1 3/32" front, 15/16" rear for all S/W.
  19. NolanRyanLady
    NolanRyanLady
    Movin right along! Thanks for the help y'all!
  20. classiccarjack
    classiccarjack
    Glad you found them, I was going to give you a sound plan "B"...
    Sent from my XT1585 using The H.A.M.B. mobile app
