Technical 63 Impala compression test results
Discussion in 'Traditional Customs' started by Eth727, Sep 11, 2024.
  1. Mr48chev
    Carbon buildup on top of a piston will raise compression not lower it.
    Add in that jumping 16 lbs when he squirted oil in that cylinder says that the rings aren't sealing.
    Any book on engine rebuilding will tell you that 36 lbs difference between high and low is too much (not over 15 max recommended) and that the engine should be rebuilt but we all know that often isn't possible nor practical at the moment.
    Personally I'd be inclined to drive it and add your favorite snake oil and see what transpires. Put a vacuum gauge on it and run a vacuum test and see what the vacuum gauge tells you. A vacuum gauge is usually pretty honest on a stock Hamb friendly engine as far as how it is working goes.
    After that if the oil pressure is good just drive it for a while.
    In truth what you do beyond that depends on what you want of the car and what you can comfortably spend and how much down time you can deal with. To me it is better to have a car that runs and drives that I can have fun with than have one torn apart because the engine is a bit tired and then have it sit torn apart for months while I manage to get it all done and back together. I used to be able to choose between a dozen good machine shops in this area to have the machine work done and now we are down to three or four that are so busy that it might take a week to get a set of heads back let alone have the heads done and the block bored.
    Tow Truck Tom and Sharpone like this.
  2. Eth727
    Eth727
    Uncle Tony’s Garage recommended auto lite plugs as wel.
    283john and Sharpone like this.
  3. squirrel
    The funny thing is that the engine doesn't know what brand of spark plugs are in it...it only knows if they work.
  4. Sharpone
    Sharpone
    Spark plugs are funny, one brand and type works well in one engine put not as good in another. I have two different engines that run best with cheap copper Champions or NGKs I have no idea why. They don’t last 100 k like the iridium’s in my late model stuff but they run better than the expensive plugs.
    Dan
    Tow Truck Tom and 427 sleeper like this.
  5. Eth727
    Eth727
    Yeah I’ll be honest with you guys . I’m not a mechanic and dont have a bunch of money but I love these cars and they’re my life. I’ve got 2 impalas. My plan is to keep ‘em running with resources that I got. You guys from the forums and YouTube are essential to getting me the knowledge to keeping these time machines alive. I chose these cars because they are easy to work on but I’m new to Chevys. I was an air cooled VW guy that did the basic stuff with an idiots guide book. So yeah the funds are sketchy thats why I’m staying at the beater daily driver cl***.
    vtx1800, 61Cruiser and Sharpone like this.
  6. Eth727
    Eth727
    These are my girlfriends. The ‘63 is a drama queen. She made me so pissed the other day I almost got rid of her but now were back in love again.
  7. Eth727
    Eth727
    #2 plug and pcv valve
    Sharpone likes this.
  8. Sharpone
    Sharpone
  9. bobss396
    bobss396
    I just picked up an OT '66 Belair that is in good shape. That has a very well running 283 with an HEI conversion. I suspect it may have an appe***e for oil, but I'm running it as-is for as long as it keeps running so well.
    Sharpone and 05snopro440 like this.
  10. Eth727
    Eth727
    What is OT? Can you do a compression test and show us the plugs?
  11. squirrel
    OT means Off Topic, which is anything newer than 65, or anything built other than "traditional". Like the wheels on the 63 you posted :)
  12. Eth727
    Eth727
    Oh yeah those wheels. I wish I had cragar ss.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    If that Drama Queen wears you out, I've a lot of patience for the needy
    :D
    427 sleeper and Sharpone like this.
  14. bobss396
    bobss396
    It runs so well I'm going to put a fresh set of wires on it. Put a vacuum gauge on it and tune the carb.
  15. 50 Merc Man
    50 Merc Man
    Sounds like a rebuild is in the near future I’m afraid
