History 64/65 Comets old drag cars lets see pictures
Discussion in 'Traditional Hot Rods' started by apound, Feb 17, 2009.
  1. 65 comet
    65 comet
    from ohio
    Thanks for the input. I think I know what im going to do. I do have another question, what do the consider a BFX? I know its a small block but what suspension do the run? Is it stock front? Have thought of doing something with my 66 mustang. Wont take as long to get done, want to go to the Hot Rod Reunion in kentucky and have some fun. THANKS, MIKE
  2. teddisnoke
    teddisnoke
    from So Cal
    Ya know- come to think of it, I want a re-match early next year! We only ran one of the match races, the other was in the elimination round, where we did not run heads up. So- I do not really consider the Peddler to be a "true" match -race winner between the two of us.:) By the time we butt heads again, the Rocket will be pared down to be more even with the Peddler...
  3. Mike, in this part of the country best nostalgia racing is in this class. Requires a stock type front suspension. Don't think they were taking Mustangs last time I checked and only take FE powered Comets.
  4. cobrajet2
    cobrajet2
    Not my video. I pirated it from the FE Forum. Sorry. Worth a look.
  5. cobrajet2
    cobrajet2
    This one is cool, too. Again, not my video.
  6. teddisnoke
    teddisnoke
    from So Cal
  7. 65COMET
    65COMET
    Mike;they do not run B/FX at either Reuninon,I don't think any modern,nostalgia races have a B/FX class.Until S/XS or outlaw tracks got involved,B/FX cars had stock front suspension.At the NHRR in Kentucky they run N/SS which is all big block cars,Fords must use FE engines.Other door cars run in HOT ROD or Gas classes.At Bakersfield and the CHRR they run A/FX which falls under the ANW rules,60 to 72 cars,engine must be same make as car,big or small block,9.00 to 12.00 dial-in,many more rules,they can and will make exceptions depending on car count! ROY.
  8. 65COMET
    65COMET
    Fast Eddie;I'm going to NHRR next year if I have to push my junk back there!!!! It looked like you needed a wing man to help fight all those scrubs in H/R!!Third time is the charm!!! ROY.
  9. Hey Roy, the Comet gathering in Tennessee is the weekend before the NHRR event in Kentucky. If you come this far East you might as well go to both.
  10. 65COMET
    65COMET
    Larry;I will need to do that.Keep me informed on date and place!!!Would be a shame to miss out on that!!!I will send you a PM with my contact info. ROY.
  11. teddisnoke
    teddisnoke
    from So Cal
    My attempt at taking some weight off the front end with cheap aluminum rims disguised as magnesium:
  12. fiveoh108
    fiveoh108
    That looks really cool!
  13. 65COMET
    65COMET
    Dale;will look good on the front! What are you doing about the boat anchors on the rear? ROY.
  14. teddisnoke
    teddisnoke
    from So Cal
    I kinda screwed myself on a set of chrome steelies I had. I had them cut to make the offset deeper, then found out that there is not enough room on the front side to make the depth I need. So- I ruined the chrome, and we are "reversing" the center to get the needed offset. I'll sandblast them to roughen them up, and hit them with the same color as these fronts. Still shedding close to fifty pounds with the new slicks over the heavy Firestones. Got a busy holiday in the garage.
  15. Falcon Gasser
    Falcon Gasser
    Who makes these? I like what you did with them.
    Jon
  16. SOHC427
    SOHC427
    Dale,
    Looking good with the new wheel idea, and thanks for the video's.
    I had some shine while I watched them all, not at 10am like Eddie!
    Eric
  17. teddisnoke
    teddisnoke
    from So Cal
    Both Summit and Jegs "house" brand. $96.00 a piece. These are 15x4. I had them sand-blasted with a more aggressive media, then shot them with VHT's "Nu-Cast" high temp paint. This paint has very fine flecks of gold and silver in it, and in the sun, it does give it a bit of a golden hue, much like the old magnesiun units. Unfortunately, the offsets they offer for the rear wheels are quite weird! Instead of making the rim dish deeper, they have made the mounting pad thicker! Oh well, mix and match for the track!!
  18. Eric
    Eric:
    I think our Drinking team has a Racing Problem! LOL!!!!
  19. Dale the wheels turned out WAY Kool! Are they center off set?
  20. Dale:
    Just looked at Jeg's, they have them on sale for $86.99 each!
  21. SOHC427
    SOHC427
    Eddie, I just got a refill last night, and I realize I need to be more pissed off that you introduced me to that shit. Good thing the wife thinks it's awful!!
  22. roosters hot rods
    roosters hot rods
    Maybe roy or fast eddie can answer a ? for me...i am under way with build a 64 falcon with a drop straight axle,small blk ford with fuel injection and a vortech supercharger...i am wondering what class this car will fall into..A f/x ? car is getting a 14 point + roll cage floaters and mono leaf in the back with hand made ladder bars..i hope to retain a ole school look with a new twist
    Rooster
  23. 65COMET
    65COMET
    Rooster;your Falcon really does not fit any nostalgia class other than a bracket type class.The East Coast and Mid West Nostalgia Super Stock classes all require a FE style engine in Ford products,a small block set up like yours does not fit their rules.Out here on the West Coast the American Nostalgia West group classifies all their cars as A/FX,big or small blocks.Most groups do not allow power adders like turbos,blowers or nitrous.Just make your Falcon safe enough to pass all NHRA/IHRA safety tech for the ET and speeds you think it will run.My Comet has more safety gear than is required but I built it for me,not for a certain class. ROY.
  24. roosters hot rods
    roosters hot rods
    Well you said it roy, im gonna build it safe and just have fun with it..i hope to have it running for billetproof drags next year,i have most of all the parts i need to put it together..i guess i should start a build thread...thanks Dave
  25. AFX DAVE
    AFX DAVE
    The guys are right about Nalstalga racing! Dennis K. was one of the First to set up Nalstalga Drag Raciin in 1985 with the PFCA ( Ford Car Club ) all the Fords or Mercury's had to be all original Factory Drag Cars w/ FE type engines. The only exception was the Factory BFX 289ci Comet. Dennis invited Z11 Chevys and Mopars that didn't have to be original, Clones were fine. They wanted all the cars to have a early 60's paint and lettering scheme.Now because the cost of the original Drag Cars are so high its best to build a clone car with more safety. Use FE engine, you can even make a 352ci run good numbers if you know what you are doing. You don't need a 427ci engine most of FE parts fit on a 352,390 or 428 block. Unless you have or earn the Big Bucks save some money and have Fun.~~~~~~~~AFX DAVE~~~~~~~~
  26. 64Cyclone
    64Cyclone
    Those look so cool I'm tempted to order a set. I posted in a Falcon thread about how I really liked Dave Lyall's old Falcon's wheels and how Rocket makes some that would be cool in the rear. I used my Torq Thrusts on another car so I'll need wheels for my Cyclone eventually.
  27. 65COMET
    65COMET
    64Cyclone;I really like those Rocket brand wheels,total nostalgia look!!! ROY.
  28. teddisnoke
    teddisnoke
    from So Cal
    Beautiful day to be out in the garage wrenchin! Forget about raking the leaves!!!!!
  29. AFX DAVE
    AFX DAVE
    More info on the Comet Winter Diet Program:
    I have been thinking about front wheels on Comet's what else!!
    Halibrands rims with 4.5 bolt pattern 15" X 4" wide with tubes using
    7.10-15 4-ply Moroso Drag Special. Weight 25# each, if you don't use
    Tubes they leak air, The problem is they are hard to find in good shape.
    Plus these guys want Big Bucks $$$$$$. That is real AFX / BFX rims.
    Cragars SS rims with 4.5 bolt pattern 15" X 4" wide without tubes using
    26 x 4.5 -15 Moroso - DS-2 tires, for racing only. Weight 32# each, No problem
    With these. Just the correct rim for the 65 AFX / BFX Comets.
    Cragars Super Trick rims, all aluminum with a duel bolt pattern 15" X 4" wide
    Without tubes using 28 x 4.5 - 15 Goodyear Eagle, for racing only. Weight 27#
    Each. A little large for a 64/65 Comet but work good on a 66/67 Comet.
    All the rims above are weight with tires. What do the Rocket Rims weight with
    The tires on them? Waiting for answer?
    The New Rocket Rims look great to me. ~~~~~~~~AFX DAVE~~~~~~~~
  30. fiveoh108
    fiveoh108
    I really like the igniters too, the only bad part about the wheels are the smallest I could find are 15x6, no 4in width wheels
