64 Fairlane needs a new heart
Discussion in 'The Hokey Ass Message Board' started by 64FordFairlane, Jun 15, 2013.
  1. 64FordFairlane
    64FordFairlane
    from Ohio
    Hello to everyone! Im new to the H.A.M.B hoping to get some advice on an old project I finally decided to get started on. My Grandfather bought me a 64 Fairlane 500 260 V8 for my 14th birthday. over the years the motor and ****** have unfortunatly both taken a dump on me. I have decided to make the car a nice street cruiser, maybe lower a lil and some new wheels. Ive been looking at putting a 5.0 with an AOD ****** in it since I know it bolts in pretty easy. Just looking for any other ideas anyone may have on motor and ****** combos, or what 5.0 and ****** I should look for. I am aiming for maximum fuel economy and dependability. Any and all ideas and advice will be greatly appreciated. Thanks Guys!!!!!
  2. charlieb66
    charlieb66
    For ease of installation I don't think you can do better than the 5.0 / AOD combo. You may want to consider changing to a carb and an aftermarket dizzy or Duraspark for a less complicated changeover. Try to find Granada disk brakes for the front.
  3. honeyman
    honeyman
    from Steiner
    Welcome to the HAMB and cool project ya got ahead of you. No Ford expert here, but I do know a warmed-up 289 will absolutely just fall into place and make plenty of power. You'd want to see what OD type trans might fit and look at rear end ratios to work towards your mpg goal. July 2013 Hot Rod magazine has several articles on 5.0 Coyote swaps into '66 Mustang, '86 Fox Body Mustang, '56 T-Bird, and '57 Fairlane and has an extensive list of suppliers for aftermarket/OEM parts. Best of luck...
  4. spiders web
    spiders web
    My 64 is a m***aged 289 hipo with a tremec 5 speed posi 9". Wild car and alot of fun!
  5. SLCK64
    SLCK64
    If you want a lot of fun, go with a stick. If you just wanna slide into D and go, find an AOD. My Comet was a 260/3-on-the-tree, swapped in a 68 302 and 69 Toploader.
    With the AOD you will have to do some crossmember work I'm pretty sure. If you go manual gotta find the pieces for all that. A T-5 is another option for fun plus MPG.
    I would go with carb over the EFI for the look or if ya can find one of the new EFI systems that will fit under the air cleaner.
    But I'll tell ya what, my 302(round 300hp, decent cam) with a 525cfm carb pull great outta the box and got some decent mpg, about 17mpgs with 3.00:1 rears and easing her up up to 55. Just now I gotta get the car back together after years of procrastination.
  6. blucarspeed
    blucarspeed
    the heart should be any sbf with a 4 or more speed. Heres mine I bought brand new at 20 years old. Its a real K code car. we ran D stock cl*** with. Good luck with your project. grandpas are special. this car will some day end up with my grandson after my son gets thru with it. there both gear heads.
    30ARoadster likes this.
  7. Malcolm
    Malcolm
    from Nebraska
    A late model roller cam 302 (5.0) with a T5 would be great in your car. Depending on your budget, you can put a cam in it, aftermarket heads, intake, and carb... and really wake it up.
    Malcolm
  8. SLCK64
    SLCK64
    Ford Motorsports did/does have, I believe, 'A' 'B' 'E' 'Z' roller cam grinds. Mild to wild. You get em for cheap and since theyre rollers, you cam get em used for really cheap.
  9. tommyd
    tommyd
    from South Indy
    I bought a 91 Lincoln LSC for 800.00 drove it home and used the 302 H.O. and AOD out of it. Did some minor trans X-member fabrication and adapted the F.I. T.V. cable to my intake and started driving it. With 4:11 gears it gets 17 mpg and is more fun to cruise now.
  10. Deuces
    Deuces
    Nice!!!!....:)
  11. JeffB2
    JeffB2
    from Phoenix,AZ
