Technical 64 Galaxy Dead at the ignition
Discussion in 'The Hokey Ass Message Board' started by 57Buick, Sep 2, 2023.
  1. 57Buick
    57Buick
    from Alabama
    My 64 is completely dead at the ignition. The battery is good and I replaced the solonoid starter under the hood and do the old screwdriver trick and the car turns over but it is not firing from the ignition. Could my ignition be bad ? How can I test it ?
    Troy
  2. The ignition switch has 4 studs- BAT, IGN, ACC, and start. Check the BAT terminal with a voltmeter with the battery connected. If you have 12V, the rest of the connections can be tested with an ohmmeter. Disconnect the battery and check between BAT and IGN with the key on. Then BAT and start with the key in start position..
    alanp561 likes this.
  3. 57Buick
    57Buick
    from Alabama
    xZ
    Awesome, thank you sir !
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not firing or not turning over? Also, when hitting with the screw driver the bypass should trigger the coil.
  5. 57Buick
    57Buick
    from Alabama
    Not turning over, dead as in no click, no nothing !
  6. ClayMart
    ClayMart
  7. G-son
    G-son
    from Sweden
    A simple test light should tell you what gets power and what doesn't. Did you check the fuses?
  8. 57Buick
    57Buick
    from Alabama
    I never thought of the fuses. I will look at that when I get home.
    Thanks
    G-son likes this.
  9. 57Buick
    57Buick
    from Alabama
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Auto or stick? If auto, is it in park or neutral or something to do with the safety neutral switch?
