Technical 64 Impala tire clearance issue
Discussion in 'Traditional Customs' started by Grat52, Aug 19, 2015.
  1. Grat52
    Grat52
    My front tires will only sit straight ahead. No room to turn!
    Tubular A-arms from Global West, dropped spindles & disc brakes from
    Cl***ic Muscle( The Right Stuff components), Torque Thrust II 7x17 rims, 0 offset, 4" backspace, 225/55/17 American Cl***ic WW tires. Tires are 26.8 tall, tread 8", section width 9" - forgot to mention 3" drop springs
    I'm thinking the drop spindles & springs are putting tire too high in wheel well?
    Rear tires & wheels are the same size as the front with no clearance issues.
    Options might be 17" rims with 4 3/4 backspace ($355ea)
    215/55/17 tires ($285 ea)
    Diff spindles ($230)
    15 or 16" wheels & tires ($8-900)
    Any ideas, please!
  2. 49ratfink
    49ratfink
    car too low tire too fat.
    glendale likes this.
  3. X38
    X38
    On this wesbite, I'd recommend normal wheels and profile rubber.
    Cartwheels and low profile tires belong elsewhere...sound like a 'restomod' site might know more.
    Bowtie Coupe likes this.
  4. 2racer
    2racer
  5. oldolds
    oldolds
    Ya think?
  6. Grat52
    Grat52
    C'mon guys, don't kick me to the curb! I shaved my handles & emblems, had my bumpers made 1 piece, blue dot taillights, cat eyes for headlights, lake pipes, white interior...white walls
    I'm not a $200k Camaro, a restored parade car or a hydraulic nightmare-I gotta fit somewhere
  7. HOTRODPRIMER
    HOTRODPRIMER
    Your front rims are too wide as is your tires. HRP
  8. DeucemanLt1
    DeucemanLt1
    You fit. Your wheels & tires don't.
    Atwater Mike likes this.
  9. Gman0046
    Gman0046
    My 63 Belair has 17" wheels, 215/45/17 front tires, air ride, no drop spindles and no clearance issues. IMG_0761.JPG
  10. Grat52
    Grat52
    Nice!
  11. Grat52
    Grat52
    It appears I have a solution to my problem. I have a set of Chevelle spindles with 2"drop & OEM specs, a local parts store cross referenced calipers from a Caprice and it looks like the rotors I have will fit. Ball joints and tie Rod fit. Gained 3/4", which gives me clearance
    May have metric hoses to figure out still
  12. texasred
    texasred
    from Houston
    "METRIC" don't live here either...
  13. Atwater Mike
    Atwater Mike
    Geez! Tough crowd here today...
  14. jeffyg82
    jeffyg82
    The brake conversion probably uses chevelle rotors n S10 calipers which push each tire 7/8 out... Solution is to get brackets from scarebird.com he uses 73 Monty rotors n 90 celebrity calipers like 380$ (brackets rotors pads bearing seals all of it) to do the whole thing and retains factory track width.... I was sceptic on celebrity calipers but they have a 2.5 piston which will be very similar to what u are using now... Fought this same problem in the last few weeks this is an excellent way to correct tire rubbing issues if you don't want to run a factory wheel tire size combo and who can blame you for that... Good luck
