64 mercury marauder rear window question
Discussion in 'The Hokey Ass Message Board' started by mercury Bill, Feb 8, 2010.
  1. mercury Bill
    mercury Bill
    Does anybody know for 100% sure if a rear window from a 64 galaxie 4 dr ht will fit a 64 mercury parklane marauder 4 dr ht?
    I haven't been able to find this info anywhere.
    Bill
  2. Yes, it's the same. Unless it's a Breezeway.
  3. mercury Bill
    mercury Bill
    Definatly not a breezeway
  4. arca39
    arca39
    from summit il
    if it looks like these two it will. just do not lay the glass down , keep it on its edges..... (it will crack) i should know, that black one was one of 4 63-64 more doors i had.....
  5. MP&C
    MP&C
    64 Galaxie rear window to compare to the above....
  6. Drive Em
    Drive Em
    The Ford in the picture looks like a sedan, and the Merc is a hardtop.
  7. mercury Bill
    mercury Bill
    I know that the 2 door ht is not the same i've measured it. Not sure about the sedan
  8. No, but a non-Breezeway four door hardtop is the same as a four door hardtop Galaxie.
  9. arca39
    arca39
    from summit il
    4dr.sedans are the same--alittle shorter then 2drs. soory about the pic of my black 64 but it is the same as the white 64 merc.both are 4dr. sedans
  10. I have 3 Galaxie 2 door hardtops to part out so hopefully someone needs glass around here for one! They do not fit a 4 door hardtop....
  11. FYI If it's a breezeway then it's NOT a Marauder:p
  12. Right. But, you know how it is on here sometimes.
