whats the hot cheap way to install ps in a 65 chevy 2wd 283 c10 pu ?? what tilt steering wheel colum will go in the easyest ??Thanks
If you go to www.67-72chevytrucks.com they have a section over there for people with your year and style truck. I bet someone there could help you with that and other questions about your ride.
get a power box off of a later pu probably 68-72. the tilt columns for these trucks are worth a fortune so look for a tilt from a 70,s van the kind without a key also you can find a column in a motorhome some times.
Try calling ELpolacko, he's in Phoenix and probably forgot more than most know about setting up what you want. He could even hook you up with some components as well. Steve 602-278-6800
I used one from a 85 chevy truck. I had to get a spacer and plate from REZ and you can use your original column, but you will have to shorten the steering shaft. If you look in my profile and go to the web site you can probably find pics. Also go to this place, they have a great tech department and you can figure out what you need. http://www.cl***icperform.com/ Good luck, Kathy
