65 comet gasser
Discussion in 'The Hokey Ass Message Board' started by 65 comet, Aug 3, 2009.
  1. 65 comet
    65 comet
    from ohio
    Hello all my first time to post here.
    My question is im wanting to build a comet gasser has anyone done this? What front axle weidth was used? Any ides on how to do this?
    Thanks for the help..........
  2. cheddar
    cheddar
    from missouri
    i have no input but i think that is a great idea!
  3. Ghost28
    Ghost28
    Sounds like fun, BUT WHO IS THIS. Just kidding go back to the new to the hamb intro section. And talk about yourself for awhile and your good to go....John
  4. BobbyD
    BobbyD
    from Belmont NC
    You really need to post an intro if you expect to get an answer, and second, do a search on here for "comet gasser", you'll see....... Good luck
  5. choke
    choke
    Me and Cometman are starting one next week. We pulled the car in the shop last night and de-bugged it w/ the vacum cleaner. This one's going to be an econo-quicky w/ a Speedway kit. The only changes I'm making is to replace axle perches and use real U-bolts w/ a bottom plate. I don't trust the standard spring perches. The axle width were using is on 46 inch centers w/an early Ford spindle kit. It looks like we can retain the stock front motor mounts even after we remove the shock towers. All we have to do is some creative gussetting. Were going use the stock steering, just fab up a new pitman arm and cross steer it. Cometman knows how to post pictures so hopefully we can get a thread going. After looking at the car last night it looks like a very simple swap. We lucked out and found some positive offset American 7" wheels,so it looks like a set of 8.5" cheater slicks will bolt on with only some frontal work on the outer wheel well. I hope that gives you some info you needed.
  6. Rich Rogers
    Rich Rogers
    I loves them 65 Cyclones but if ya got one ya gotta put up some pics
