'65 F100 lowering help?
Discussion in 'The Hokey Ass Message Board' started by 4Speeds4Ever, Jan 12, 2011.
  1. 4Speeds4Ever
    4Speeds4Ever
    ...so I have a '65 Ford F100 shortbox 2wd, and I would love to lower it some. I found this pic in the F100/F1 picture thread, and it's PERFECT!
    I get the lowering blocks on the leafs out back, but how does one go about dropping the front on a Twin I-beam set up without screwing up the camber?
    I have to go through the entire front suspension anyway - the steering is loose as a goose and vague as hell - so I figure I might as well make it look how I want while I do it! :D Any help would be vastly appreciated!
    TIA, Drew
  2. art.resi
    art.resi
  3. 69supercj
    69supercj
    There's an active thread about using a Jag front-end. Supposed to be a fairly easy and straight forward swap and the results look very good and the handling/braking is supposed to be outstanding.
  4. 4Speeds4Ever
    4Speeds4Ever
    looking a bit more budget-oriented here... :D
  5. 69supercj
    69supercj
    Well I found a jag front end for 250 bucks, pretty cheap I'd say. You should be able to do the job for less then 500 if you shop around and do your own welding.
  6. art.resi
    art.resi
    Dream beams on the bay less then 500.
  7. Turbo Rocket
    Turbo Rocket
    from Iowa
    My 64 has a mustang II front end with rack and pinion steering, and sit as low as you can go with out changing the cross member. Rides and drives really nice. I bought the truck from Nick (malcom) on the board. There is pictures of the truck and front suspension if you look it up under his name.
  8. The truck you have pictured is a '64 with a solid 'I' beam axle, much easier to lower. I'm installing a Crown Vic front crossmember ass'y on a F100. Very easy and should ride nice and low, not cheap though.
    If you are going to rebuild the front anyway, mybe you should think about geting a complete front axle ass'y from a '72/'76 F100.....it's a bolt in, power disc brakes, power steering, etc.
  9. 69supercj
    69supercj
    My '66 has a MII under it and its nice and low.
    Way2fast likes this.
  10. Dream Beams from DJM Manufacturing are the easiest and most economical way to do it right.
  11. 4Speeds4Ever
    4Speeds4Ever
    I like the simplicity of non-power steering....and I'm sure once the Kingpins and bushings are squared away the truck will steer a lot more nicely...I'd really just like to hunker it down. Are there any bolt-on spindles with built in camber adjustments, maybe from a later Ford?
    I DO, however, want to upgrade the single reservoir master to a dual, non-power assist...I've heard that '73-'79 F-series trucks have a drop-in replacement....can anyone confirm that? The stock drum brakes really work quite well, no need to upgrade to discs that I can see.
  12. willowbilly3
    willowbilly3
    from Sturgis
    that's 64 in the picture, a whole different beast than a 65. I think you will have to front stub the 65. A friend of mine put a Crown Vic front stub on a 68 shortbed (same frame as yours). It worked really well and gave the truck the same stance as the green 64.
    The 70s front ends are pretty much a drop in for disc brakes, if there is such a thing with Ford. But you still can't lower them much. No spindles that I know of and some lowered I beams but I haven't talked to anyone who was happy with them, you have to butcher up the steering arms and they don't turn very short after that.
  13. 69supercj
    69supercj
    I just put a dual res M/C in my '66 and used a new 68 Mustang M/C for front disc, non power. It came with 2 push rods and I was able to grind one of them just a tad to make the pedal come out at the right height. You can make an adjustable rod with a threaded sleeve and a die if you need to, just make sure you use some jamb nuts to secure it.
