Technical 66 f100 drum to disc front brakes
Discussion in 'The Hokey Ass Message Board' started by Hood Pope f100, Dec 22, 2014.
  1. Hood Pope f100
    Hood Pope f100
    Need help with swap
  2. King ford
    King ford
    from 08302
    I took the spindles ,calipers and rotors off of a mid 70s half ton.....bolt right up,....been a long time ago, but you may have to go to later tie rod ends, I think the tapered portion that goes in the spindle is longer....
  3. Hood Pope f100
    Hood Pope f100
    How did you run the brake lines
  4. King ford
    King ford
    from 08302
    I drilled a hole in the frame rails and used the "c" clips to hold them in, also used power brake booster and dual res master cylnder ...
  5. Hood Pope f100
    Hood Pope f100
    Thanks for the info
  6. Hood Pope f100
    Hood Pope f100
    Forgot to ask if it is possible to use f250 disc brake setup
  7. Mr48chev
    The king pins are the same from 66 up through 74 so that should give you an idea on what years might work and be pretty much a bolt on deal. An early 70's F250 shouldn't be hard to find with the front brake pieces and spindles on it.
  8. Hood Pope f100
    Hood Pope f100
    I thought so thanks for the info
