660.
Discussion in 'The Hokey Ass Message Board' started by Hubbcat, Dec 3, 2011.
  1. Hubbcat
    Hubbcat
    from Sweden
    Need alitle expert advice.
    Bought a par of hollye 660 race carb´s.and i see that they had holes in the trottelblades,should the bee there???????
    Or is there a home mechanic that want to get more air in the motor ?
  2. Jack E/NJ
    Jack E/NJ
    from NJ
  3. slickhale
    slickhale
    from Phoenix
    yes they should be there
  4. Hubbcat
    Hubbcat
    from Sweden
    Thanks i think the look stock,but i didnt know.
    Many people drill them holes to let more air in,when they usa a BIG cam.
  5. Hubbcat
    Hubbcat
    from Sweden
    Okay secund opinion????????
  6. gasserjohn
    gasserjohn
    repeat of edelebrock/holley directions.....
  7. chevguy
    chevguy
    ^x2
  8. Hubbcat
    Hubbcat
    from Sweden
    Thank´s a lot.
  9. gasserjohn
    gasserjohn
    more.......
  10. Deuces
    Deuces
    My 850 cfm LIST-4223 "Center Squirter" carb has those also...
  11. Hubbcat
    Hubbcat
    from Sweden
    Working on a 66 chevy II 2door post gasser style ,and run in to this tunnelram with 2 660 hollye`s,that would fitt great!!!!!i think?
    Gona look f**ng great anyway.
  12. Hubbcat
    Hubbcat
    from Sweden
    Yes the are center squirt allso.
  13. 296 V8
    296 V8
    from Nor~Cal
    My two 660's (fresh HOLLEY rebuilds) have no holes.
  14. Hubbcat
    Hubbcat
    from Sweden
    wtf?????????????????????????
  15. 296 V8
    296 V8
    from Nor~Cal
  16. Hubbcat
    Hubbcat
    from Sweden
    Just want a opinion?
    Or the wright way
    Do the come with holes or NOT.
    HOLLEY 660.
  17. Deuces
    Deuces
    And very rare too!!! Not many were made... ;)
  18. 296 V8
    296 V8
    from Nor~Cal
    Id contact the holley rebuild shop ……. I think iv emailed them before.
  19. Deuces
    Deuces
    The early versions probably never had holes.... Check with Holley..
    www.holley.com
    Good luck!
  20. Hubbcat
    Hubbcat
    from Sweden
    Maybe yours are wrong?
    Have a 500 hollye cfm,that have holes in the trotellblades?
  21. Hubbcat
    Hubbcat
    from Sweden
    Have chekt with holley and they did not have a expoding wy off 660`s
  22. 296 V8
    296 V8
    from Nor~Cal
    My pair are basically new
    If I didn’t know holley rebuilt them Id swear on my life they were NOS …. they are that nice and its very doubtful to me holley doesn’t know the correct parts to put on them
    I don’t know what to tell you other than
    You asked ... so ...we told and gave you a option for more info.
    BTW
    My 450's have no holes
    Your welcome
  23. Jack E/NJ
    Jack E/NJ
    from NJ
    You can run the plates with the holes. Then run them without by plugging the holes with solder. Then choose what you like best. You're a lucky guy. 8^)
    Jack E/NJ
  24. Deuces
    Deuces
    That's crazy!!! What if that solder breaks off the throttle blades and does the "happy dance" between the heads and pistons???.... No thanks!
  25. Jack E/NJ
    Jack E/NJ
    from NJ
    Nah. Even if it did, which is highly unlikely, the small flake of soft solder wouldn't do the kind of damage the allegedly-staked screws holding the plates to the shafts do when they come loose. Perhaps you haven't seen this happen....yet. 8^)
    Jack E/NJ
  26. Larry T
    Larry T
    Some combinations need the holes in the plates, so that the engine gets enough air to idle with the throttle blades closed. If you have to open the blades to much at idle it uncovers the vertical transition slots above the blades at idle and effects the way the carb reacts off idle. So it's not a one way is right and the other way is wrong kind of deal. Every combination is a little different, one size doesn't fit all.
    Larry T
  27. Jack E/NJ
    Jack E/NJ
    from NJ
    Larry T>>>Every combination is a little different, one size doesn't fit all.>>>
    x2
    Jack E/NJ
  28. Avgas
    Avgas
    I have run 660's for years and never seen "factory" air holes in any of the sets I have owned or worked on. If your running an auto trans you may want to slow the secondries by re phasing them with some sculpting around the throttle linkage, food for thought!
