67 GM steer column harness
Discussion in 'The Hokey Ass Message Board' started by bustingear, Oct 6, 2012.
  1. bustingear
    bustingear
    Working on my 28 sedan and usingg a 71 Chevy truck column with the curved plug in. Since I will not be using this plug in I am trying to figure out what color goes where.
    I have
    Purple
    Blk/yellow
    Green
    Blk/white
    Black
    Blk/lt blue
    Blue
    Brown
    Any decoding of the colors would help
    Thanks much
    Gear.....
  2. Cerberus
    Cerberus
    In the back of Haynes CHEVROLET & GMC PICK-UPS Repair Manual 1967 thru 1987 are wiring diagrams. The curved plug is labelled DIR. SIG. CONN.
    The purple wire goes to fuse panel.
    The Yellow wire goes to the tailight harness connector
    The green wire goes to the taillight harness connector
    The brown wire goes to the fuse panel
    The blue wires go to the cluster connector.
    Having the repair manual in front of you and seeing the curved wire connector labelled will let you know what goes where.
  3. bustingear
    bustingear
    Well I am using a Keep It Clean harness and there are wires that come out to meet the column wires. I need some more detail on all eight of those wires.
    Thanks
  4. Cerberus
    Cerberus
    Here is the pic of the DIR. SIG. CONN.
    You asked for info on BLK wires with diff colors that aren't in the illustration.
    One of the two LBL wires goes to the Bulk Head Connector. The other goes to the Cluster Connector. Sometimes I've found it hard to see the real colors of the wires unless they are cleaned first.
    The Mustg II column on my "Special Constr" car has ten wires coming out of the plug. At 35 years old, it was difficult to determine their color and the stripe color on them, until I cleaned them with solvent. I used a Rebel Wire 9 + 3 Hot Rod Harness and every wire does what it is suppose to. I had to call Rebel to get some clarification.
  5. Dammit
    Dammit
    from Canada
    bustingear, had a look in my Haynes manual, and it's a little hard to make out. But here goes: black/light blue..............left front signal and indicator
    dark blue......................right front signal and indicator
    black...........................horn ****on
    black/yellow..................left rear signal
    dark green....................right rear signal
    black/white...................feed from brake light switch
    purple..........................power to signal flasher
    brown..........................12v
    Hope this is helpful, not sure on the brown wire, but this will get you close enough.
  6. bustingear
    bustingear
    Yes thanks exactly what I needed. I like you am perplexed by the brown wire.
    Cerberus thanks for your efforts a well.
