69 Dodge 383 for my 27 roadster...Thoughts?
Discussion in 'The Hokey Ass Message Board' started by 90ssp, Nov 17, 2009.
  1. 90ssp
    90ssp
    from dallas, ga
    I'm going friday to look at a 69 dodge 383 for my 27 dodge roadster. It has an aluminum intake and 906 heads...I wanted a hemi but I couldnt find one near this price...I know its not traditional but it should definitely "roast" some white walls:) I'm also going to build a new frame to handle the extra hp...
  2. hotrod-Linkin
    hotrod-Linkin
    mopar theme is good.
  3. 90ssp
    90ssp
    from dallas, ga
    Thats exactly what I was going for. It has a 305 in it now...thats gotta go
  4. hotrod-Linkin
    hotrod-Linkin
  5. patrick66
    patrick66
    A Mopar-powered hot rod is always a good idea! I'm installing a '69 440 in my '56 Ply wagon. Pics??
  6. 90ssp
    90ssp
    from dallas, ga
    I'm hopefully going to get my 2x3 tubing for the frame this week and start taking everything apart and building this roadster right. I want to do a whole different rear suspension to make it more sturdy and "safe." Then one the frame is done then it will be time to fix the body and get the windshield back on along with building a partial hood for it. Some custom headers to make the neighbors mad:)...SOOOO much to do!!
  7. hotrod-Linkin
    hotrod-Linkin
    randaddy has some dodge roadster bodies and parts. he's an okie .
  8. Retro Jim
    Retro Jim
    I am with you on that damn chev motor ! Every Mopar deserves something better than a run of the mill sbc . I have a 37 Ply. p/u that I want to get a 383 or 440 Mopar for but can't afford on yet . I have a nice Ford Y block w/3x2 and big cam and all the other stuff to put into my 37 if I can't get a BBM .
    Keep the pics coming when you get that BBM in your roadster !
    RetroJim
  9. Dave B.
    Dave B.
    I like the Mopar/Mopar theme, too.
    Just be prepared for the additional weight. The 305 probably weighs around 525-550 lbs. The 440 comes in around 670.
    A build thread on that critter would be great! I don't think I've ever seen a 440 in an early roadster.
  10. jaxx
    jaxx
    Great choice for power - lots of boosting parts for 383 - Ive run lots of mopar big blocks and love them all - Im going with a donated 318 in my 25/26 DODGE rpu build but am looking forward to seeing how yours come out just incase I want to UPGRADE- Ja**
  11. moparforlife
    moparforlife
    from Rolla, MO
    Same here. You might want to get rid of the 906 heads if you plan on driving it quite a bit though (unless you put in hardened seats). 452 heads flow the same and already have hardened seats, so they would probably be a little more street friendly since you don't have to add lead to every tank. If you plan on building it, there aren't many better or cheaper builds than Mopar Muscle's Resto to Rad 383. http://www.moparmusclemagazine.com/techarticles/mopp_0209_383_engine_restore/index.html
  12. 90ssp
    90ssp
    from dallas, ga
    thanks guys!!
  13. robt500
    robt500
    from Lex, KY
    uh... hell yeah
  14. Captain Chaos
    Captain Chaos
    from Missery
    383 is a fine motor , make plenty of power ins tock form . put that 305 chity in the s**** heap where it belongs
  15. 57JoeFoMoPar
    57JoeFoMoPar
    Who says it's not traditional? The 350 B motor was available in '58. 383 looks as much or more like one of those as a 305 looks like a 283. There are some cool dress up parts out there for the 383, but you gotta hunt for em. Not like the SBC where cool dress up part will smack you in the face. You'll be rewarded nicely by a fine running/performing reliable mill
  16. twofosho
    twofosho
    Weight and torque of a big block Mopar, even a 383, is going to need a real stout frame. 2" X 4" or 2" X 6" rectangular tube will make for a much stronger frame than that 2" X 3" you're considering.
    Another idea is to find a stock Dodge frame of near vintage. Six inch deep rails with big sturdy crossmembers. Box one of these frames and it should stand up to even a HEMI. Semi elliptic springs front and rear locate the axles and simplify suspension issues. Stock fuel tank is carried behind the rear axle like most "modern" cars. I'm going to run a double dip tube front axle from a '37 Mopar of some sort in my '28 frame along with a Mopar power steering box.
  17. 90ssp
    90ssp
    from dallas, ga
    You may be right on the 2x4. I may do that instead
  18. holeshot
    holeshot
    from Waxahachie
    hey 90SSP...man i love those 383 mopars, and don't be concerned about the weight. that 383 has some bigtime torque. mopar mills have allways been very reliable too! good luck with your project. call me POP...or the old FART!
  19. 90ssp
    90ssp
    from dallas, ga
    Thanks...that article has some good info
  20. onlychevrolets
    onlychevrolets
  21. 90ssp
    90ssp
    from dallas, ga
    now i just have to find the 4 speed trans now
  22. Just tell everyone its a 413. :D
    I guess I don't see anything wrong with dropping something as non-trad as a high grunt big block in an old roadster. Paint "Anti-Rod ! ! ! " in large letters on the deck lid. They should be able to read it if they took the Evelyn Woodhead Speed reading course.
  23. DE SOTO
    DE SOTO
    Why not use the '27 Dodge Frame ??
    Way Stronger than any 2x3 Tubing & actually looks like a FRAME, Not 2 sticks of s**** metal.
    I used a '26 Chrysler frame under mine with a DeSoto Hemi.
    LOVE Them MoPaR Frames !!!
    I have an Rebuilt Early 413 in the Sale adds that needs a new home for those interested.
  24. artiep
    artiep
    I got a 383 sitting in my garage waiting to be put in my 1988 Dodge pickup replacing the 318. Its a good solid motor, parts are a little more expensive though.
  25. rjgideon
    rjgideon
    Mopar wedge big blocks came out in 1958, it's traditional-ish.
  26. Swifster
    Swifster
    383's came out in '59. It's as traditional as a 327. A few even had the long ram (Ram-O-Sonic) intakes on them.
  27. Big Block Mopar? Hell yes!
    I have a '75 400 in my '48 Dodge pickup and I think it looks as traditional as anything out there
    Stock 383, very tough motor, tons and tons of potential there as well.
    Don't go too nuts on the cam and you will be very happy, especially in that light of a car.
    Good choice my friend, I am starting to tear up a little here . . .:D
  28. 90ssp
    90ssp
    from dallas, ga
    there are areas of the frame that are suspect so thats why i wanted to build another frame. I want to make it as safe as possible because my 2yr old daughter loves it and will be riding with me
  29. 90ssp
    90ssp
    from dallas, ga
    Thats a nice 400. My other option is a 76 440 that is bored 30 over....decisons....
  30. Circus Bear
    Circus Bear
