-6AN Feed split to Two Holleys.... -6AN sufficient ?
Discussion in 'The Hokey Ass Message Board' started by awsomeears, Mar 28, 2012.
  1. awsomeears
    awsomeears
    Just wondering if my fuel size will be sufficient...
    ---- = Line ;)
    Tank------------ Carter Mech Fuel pump-----Regulator----- Fuel Block ------ Two Holleys 450cfm
    And yes there will be a filter :)
    Tank to Mechanical pump is probably 8' ( 63 nova )
    The motor is by no means a race motor :) 400 sbc 9:75to1 very mild cam, cast iron heads....
    On my fuel block I will be mounting a nice PSI gauge.
  2. squirrel
    should be fine. The engine HP kind of determines how much fuel you need.
    I'm running a single line to feed two holleys on my blower motor, but I have an electric pump back near the tank. I don't even remember what size the line is, I'm thinking -8 but it could be -6. been 15 years or so since I put it together
  3. Boryca
    Boryca
    from Detroit
    -6 is a 3/8 line, so you'd probably be just fine. I'm ***uming here that you've probably got a 3/8 line from the tank anyway, so anything larger than that wouldn't really make a whole lot of sense unless you want an 'in-line reservoir'.
  4. awsomeears
    awsomeears
    Squirrel thanks for the info...
    I was going to go the Electric Fuel pump route but for the Look of my G***er I'm going for the Simple Look at Era correct, plus all in all the motor is perfect for now. I plan to drive the **** out of this car, love to take a cruze 1-3 hours away to a car show...
  5. awsomeears
    awsomeears
    Boryca, you are correct I have a nice braided 3/8 line currently, just putting a tunnel ram on it where there wasn't one
    :D
  6. II FUNNY
    II FUNNY
    When you get it all sorted out you can bring it to the Meltdown Drags in Byron Ill. this july 21-22 ,check out the web site for more info www.meltdowndrags.com
