Technical 6V 12V Flathead
Discussion in 'The Hokey Ass Message Board' started by bustingear, Oct 31, 2019.
  1. bustingear
    bustingear
    Converting my 1950 8BA to 12V . I have heard that the starter can be used. I have purchased Powermaster alt.
    Question is on stock oil and temp sensors. Can they be used in 12V conversion.
    Thanks
  2. brake1000
    brake1000
    from ID
    Lots of info over on the Ford Barn on how to do the conversion.
  3. Stock oil and temp sensors are fine with 12V. You'll just need to change the bulb that illuminates the dash.
    GAUGES will need either a runtz resistor, or the later Ford style resistor mentioned in numerous threads on this subject across the web.
    Flathead Dave likes this.
  4. bustingear
    bustingear
    gauges will be aftermarket 12v thanks
  5. 19Fordy
    19Fordy
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    yes you can use the 6v senders. I have been using them and the 6v starter for years.
    No worry's...
    Sent from my SM-G973U using The H.A.M.B. mobile app
  7. If you are using aftermarket gauges, they are probably 12 volt gauges and they will require a compatible sender. I doubt that the flathead senders will work with those gauges.
