6v heater in 12v car who's running one
Discussion in 'The Hokey Ass Message Board' started by oddrod46, Nov 23, 2009.
  1. oddrod46
    oddrod46
    from Georgia
    All the cool old heaters are 6v. can you run a reducer and be good to go? need a heater in my daily driver 41 ford
  2. 49ratfink
    49ratfink
    I didn't even run a reducer. fan just goes a little fast.
  3. Crestliner
    Crestliner
    I ran one on my 37 p/u. Didn't run it on high, no problems.
  4. oddrod46
    oddrod46
    from Georgia
  5. HemiRambler
    HemiRambler
    I ran mine on 12 volt - as said it ran fast. I always figured when it burned up I'd replace the motor then - still waiting.
  6. 31ACoupe
    31ACoupe
    you should put reducers on the switch, one for each speed, for best operating results.
  7. junkyardroad
    junkyardroad
    from Colorado
    The original 6V heater has been running in my 54 Ford with a reducer from Speedway for 4 years with no problems.
  8. 29nash
    29nash
    from colorado
    6v heater with reducer, works great.
  9. SAL RANDA
    SAL RANDA
    hi ive been running 6 volt heaters for years just put a reastat switch in that adjusts the speed and keep warm it works fine sal randa:)
  10. Road Runner
    Road Runner
    I've been running a high wattage resistor between the switch and heater motor on both my daily rides. One for 14 years now and never had any problems.
    A resistor/reducer should be used. The small resistor across the heater switch for medium and low settings is not large enough for 12V main voltage.
  11. Zombie Hot Rod
    Zombie Hot Rod
    from New York
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    I replaced the fan motor with a 12V part. Look through the parts books at NAPA and you should be able to find one that fits.
  13. Retro Jim
    Retro Jim
    A cheap $15 reducer from Speedway will be all you need .
    RetroJim
  14. gas pumper
    gas pumper
    54 Chevy, no resistor. not much heat air flow out of it either. But no problems.
  15. 4speedman
    4speedman
    6v blower in my 50 chevy 12v system for 10yrs no resistor, goes like hell defrost works great and will run you out in 20degree weather, I say hook it up and don't sweat it (no pun intended)
  16. Hemi325
    Hemi325
    from Boerne, TX
    I got two resistors from Napa and run an old 6V Firestone heater with a rheostat switch. Works like a champ.
  17. I recommend a resistor or reducer. That one posted in a picture a few posts up is the type I like best.
    Even if you are willing to live with an over-speeding blower motor, you need to take into account that they sometimes throw off of the armature windings when they run too fast.
    If that happens you could suddenly end up with a cold car or possibly even smoked wiring.
    I remember long ago, we would often put in a blower motor from a 12V car very easily.
    I suppose you could still do that today. I would imagine that parts stores still sell the 12V versions that easily mount in the old heater.
  18. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, I considered just running my 6V motor on 12V but decided against it – even though as a kid I used to run motors meant for 3V (scavenged from toy cars) on a couple of nine volt batteries wired in series. And I don't remember smoking one of those toy motors with 18V either.
  19. patrick66
    patrick66
    Here is my question then - If I hook my 6VDC heater motor to 12VDC, would it work better with a 12VDC rheostat, or with a 12VDC on-off switch (or a off-lo-hi switch)??? Since you guys have had good luck running yours without a stepdown voltage relay, what works best?
    That switch, mentioned above for $14.95, looks like the solution to me. I'm trying to go cheap, but don't want to fry my car, either.
  20. Remember that a voltage reducer works by increasing resistance in the circuit When you increase resistance, you produce heat. Those resistors can get pretty hot, so be careful where and how you mount them, as they can be a fire hazard if you're not careful.
