6v negative or postive ground??????
Discussion in 'The Hokey Ass Message Board' started by Wallace32, Mar 18, 2006.
  1. Wallace32
    Wallace32
    from Manheim
    I just got a 1953 Ford Mainline with a straight 6 and trying to figure out from some old articles if the car is positive or negative ground. looks like in the service manual it's showing + ground. but when i got the car home and did a tune up it's been running - ground, gas gauge and flashers dont work so i was thinking if its backwards might be causing the problem. oh any ideas on how to cheaply dump the front in the weeds?
  2. chrisntx
    chrisntx
    from Texas .
    53 Ford was positive ground
  3. 302GMC
    302GMC
    from Idaho
    How was the battery installed? If it was hooked up neg. grd.,turn the lights on and leave it overnight ... next day, hook up the ground to pos., charge it, and you should be set. Don't forget to polarize the gen/reg., which I'll leave to a 6 volt Ford person to explain ...
    302
  4. chopndrop
    chopndrop
    hey 302, why do you have to drain the battery to switch the polarity? I never heard of that.
  5. 302GMC
    302GMC
    from Idaho
    If it was installed backwards, it's charged backwards. Batteries can be charged either way ...
    302
  6. chopndrop
    chopndrop
    So are you saying that if someone hooked up the battery wrong, in this case negative ground when its supposed to to be positive, that the battery would change polarity? Wouldnt this damage the battery?
  7. 302GMC
    302GMC
    from Idaho
    Doesn't seem to cause any problem - saw it many times, always worked great once charged correctly ... has to be a serviceable battery to start with, of course.
    302
  8. Bugman
    Bugman
    It's a little known fact that if you take a car battery down to zero charge, you can reverse it's polarity and charge it backwards.
    In your case, as long as theres no current flow, having it hooked up backwards for awhile wont hurt anything.
  9. gasheat
    gasheat
    from Dallas
    Every car I have had that was 6 volt was positive ground.
  10. But not every 6 volt car is positive ground, nor is every 12 volt car negative ground, you must have it hooked up correctly for the system to operate correctly.
    Cosmo
    P.S. He's right about the charging backwards thing; I've done it with a charger that had unmarked leads.
