6V start button question
Discussion in 'The Hokey Ass Message Board' started by 55 Post, Nov 8, 2009.
  1. 55 Post
    55 Post
    from So Cal
    Hi,
    I've been scouring the board for more inforamtion on how to wire a 6V (positive ground) push start button using a relay, but no luck.
    Currently running a 56 Olds 324 in a Model A running 12V negative system, using an aftermarket wiring harness. I have:
    A: Push button start
    B: 50 something ignition ( Acc, off, on) for fuel pump.
    C: Kill switch for Mag.
    Right now I have the relay wired as follows:
    87 ground
    85 12V constant
    86 Push button
    I can push the starter button, get the relay to click, but no voltage at 87 A or 30.
    Afraid to jump any wires and let the smoke out...
    Thanks in advance,
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    The push button don't care about voltage. If this is a old Ford button they were a one wire ground to work the solinoid. If your relay needs power to work you will need a 2 wire button.
  3. 55 Post
    55 Post
    from So Cal
    Thanks for the help 440!! That did the trick.
    One step closer to being on the road....
