6v starter problem...
Discussion in 'The Hokey Ass Message Board' started by Remely54, Apr 27, 2008.
  1. Remely54
    Remely54
    Can anyone help with this problem of mine. So about 3weeks ago I did the 12v conversion on 54 chevy. Manual said to continue using original starter till it whent, so its fried but now which starter can I use to replace the 6v. The motor is the straight 6cyl 235. Off of which car or should I use the starter, any info would help thanx...:D:confused::confused:
  2. Truckedup
    Truckedup
    6 volt Chevy starters have a flywheel gear with 139 teeth,12 volts have 160 ish teeth.You can't use a 12 volt starter as is on a 6 volt flywheel.The starter drives won't interchange between 6 and 12 volt that i know of. You can have a starter shop rewind your starter for 12 volts I suppose.
    My 50 Chevy pu is 12 volts using the original 6 volt starter for the last three years.I've had no problems with it,but I don't crank it very long.Guys tell me the brushes wear faster,I checked them out,they were ok ,I keep a new set around just in case.
    If you can dis***emble the starter yourself ,check it out,might just brushes
  3. tommy
    tommy
    What he said. I've had 2 6V starters rebuilt as 12V units by a starter/generator shop. Not on the same car or engine type!:D
  4. Remely54
    Remely54
    Thanx ill try that..:cool:
