Technical 6volt distributor options for an 8BA
Discussion in 'Traditional Hot Rods' started by Speedster, Jan 28, 2025.
  1. Speedster
    Speedster
    from Tacoma, WA
    I’d like to keep the 6 volt system on my 8BA. The engine is freshly rebuilt as are the generator and starter. I’m planning on running two 97s and would like a 6 volt mechanical advance distributor. I have a couple of Mallory dual point distributors off a SBC, and can do the machine work for the.8BA application. But is it possible to convert them to 6 volt? If so, what parts are needed? Different coil, condenser, etc.
    Thanks in advance for any help you can provide.
    John
  2. Budget36
    Budget36
    I’ve never gone from 12 to 6, but when going 6 to 12, I just changed the coil, used a ballast resistor and used the same condenser that was used for 6 volts. if you think of the condenser as a capacitor, you’ll never find a 12 volt or 6 volt capacitor, 50, 100 etc volts.
    Speedster likes this.
