6x2 Blower Top - a little progress
Discussion in 'The Hokey Ass Message Board' started by Tudor, Jul 8, 2006.
  1. Tudor
    Tudor
    from GA
    Check out the 6 2s on top of the 6-71. That is one of Savages ***y ***ed blower tops. Nice work Savage - mine is serial number 0010. Still working the pulley's out, I am going to end up running a 2" gilmer belt and be like 70% underdriven to start with. I think I am now going to be able to keep my mechanical fan. It was a major accomplishment for me just to get the blower to the house ready to go with the drive because I did it as cheaply as I could. It all started when my buddy gave me a 671 straight off a diesel. I sold that one to a local guy then won an auction for a rebuilt 671 off of ebay. Then I had to find a cheap drive. Found that on ebay too.
    A lot of people ask what all has to be done to a diesel blower to run it on the street. First of all you have to take the rotors out and flip them around and swap the bearing plates from end to the other on the housing. Then the guy triple pins the drive gears to the rotors, timed the rotors so they are in the correct relationship to each other clearance wise, pinned the bearing plates to the housing to maintain the rotor to housing clearances once they were set. He changed the rear bearing plate to a magnesium littlefield plate with a dog bone cover that goes over the bearings. I should have gotten the front one too but I was trying to save money so I used the original 671 front cover. You'll never see the rear plate but it has better bearing support so it will at least work better than using the 671 rear bearing plate. He also changed the bearings - rear one are regular sealed bearings and the front are oil bath. The front of the case has oil and is sealed.
    The engine is a 283 - 30 over. I have a 292 Clay Smith solid lift blower cam, 882 heads with 1.95 1.50 stainless valves, I had the machine shop set the springs at 140 lbs seat pressure per the cam specs. I can't remember what the cam card had on it but it was a fairly moderate lift cam - like 465 or something. I'll check that and update it.
    The carbs are holley 94’s. I am going to run the outer carbs as dumpers without idle circuits, modified bases so the ****erflies close completely when shut. They’ll be actuated with progressive linkage. I think I’ll open up the front two then the rear two so all 4 don’t get slammed open at the same time.
    Then for the center carbs I have two holley 94 2110s – the large cfm 94’s with idle circuits. It ought to act just like a GM tri power just times 2. ****ster is building the carbs for me.
    The car has 3.80 gears and a 4 speed. It ought to be a screamer. Just thought I'd see what you guys thought about the motor combination.
  2. flamedabone
    flamedabone
    What, you can't fit eight of em on there..?
    Looks killer. -Abone.
  3. drhotrodmd
    drhotrodmd
    Holy **** man that looks great!
  4. Tudor
    Tudor
    from GA
    Thanks dude - want to donate those FI stroms??????? ha ha - I saw those on ebay.
    Hey Jeff - If it had been a pocho I would have had to have 8. :D
  5. Boones
    Boones
    from Kent, Wa
    Josh, that looks *****in, this car is going to be so much better then the sedan. I like what I see.
    Damn, are those my nicely painted chevy valve covers we traded for.. OUCH...
  6. drhotrodmd
    drhotrodmd
    Yeah i changed my mind and their still on the car.
  7. Tudor
    Tudor
    from GA
    Thanks Boones - no those are some 10 dollar swap meet specials - they are beat to ****. I have something real nice planned for the valve covers. :D
  8. Circus Bear
    Circus Bear
    ****in sweet brother. good thing you rebuilt that motor before puttin all them carbs on. I can't waite to ride in that thing (thanks for unchanneling so I can fit!) it's gonna rock.
  9. D.W.
    D.W.
    from Austin Tx.
    Nice to see someone put one of those to good use. Looks killer!
  10. Jeezus, Josh, that is looking great. Right on brother.
  11. kustombuilder
    kustombuilder
    from Novi, MI
    DAAAAAAMN!!! thats nice.
  12. junkyardgenius
    junkyardgenius
    from Kernow
    Re diesel blowers on hot rods, another good tip I picked up years ago was to make up steel support rings to fit around the bearings in both bearing plates so you can use the stock bearing plates.I,m afraid the picture isn,t very good but I had to scan it.
  13. Tudor
    Tudor
    from GA
    Yes that would help and reinforce the metal around the bearing.
    I spoke with ****ster yesterday - the dumper end carbs are done - woo hoo.
  14. SAVAGE
    SAVAGE
    Alliance Vendor
    I think I just CAME
    Awesome
  15. hayden1951
    hayden1951
    I just came across your post about your 6x2 carb adaptor.How did it work out? Any thing you would of done different? im just starting my first blown motor.I got an old crager 6-71 and i want to run 6- 94s.tHANX.
  16. ahgarageohio
    ahgarageohio
    from ohio
    That is bad***!!
  17. Ace50coupe
    Ace50coupe
    from Indiana
    Man that is sick. im wanting to do that with a sbc of mine. How much does he charge for the blower plate just curious?
  18. Tudor
    Tudor
    from GA
    Check out www.savagespeed.Com if i remember right. He sold them for 500. Man this is a blast from the past! I ended up changing directions and sold the carbs. I still have the 6x2 adapter.
  19. PBRmeASAP
    PBRmeASAP
    holy ****....2006! wow that's a blast from the past.
    amazing how far you have come with the coupe'
  20. Boones
    Boones
    from Kent, Wa
    I was in ATL for a 3 hr lay over on Friday. I thought about how long since i have seen some of your guys on that side of states...
  21. Tudor
    Tudor
    from GA
    Ken! Give a shout if you're nearby!
