6x2 Carb Set Ups - Pics and Information?? - who made them?
Discussion in 'The Hokey Ass Message Board' started by arkracing, Aug 1, 2006.
  1. SPAM Alert! (and 10% off for Alliance Members)
    You could always use this item from O'Brien Truckers made for a 4-71 blower.
    PM me or e-mail me at obt@charter.net for more information and pricing.
    Dennis
  2. beatnik
    beatnik
    You've been busy Dennis, that rules! and it would go great topped with some of these.
    So what else have you been cooking up for us?
  3. wooh - I didn't know you had those!!! the air cleaners look great too -
  4. arkracing
    arkracing
    Yeh No Kidding - when did you come up with those? something you still produce or were they a limited production run???
    Got a Picture of one on a 4-71???
    Where can I find scoops like this for 94s? Those are 94s, right?
  6. tommy
    tommy
    Nope they're 97s
    94s have the fuel inlet in the carb top.
    97s have the fuel inlet in the body of the carb. Just check the fuel inlet to tell them apart.
    I don't know who makes the pointed scoops.
  7. 32chevysedan
    32chevysedan
    from Texas
    Is the carb. top on a 94 and a 97 different sizes where the scoop will bolt?
  8. Thanks, that makes it easy to spot.
  9. If you're asking what I think you're asking, yes the 97's and 94's (and 48's and most Rochesters) have 2 5/8" carb necks.
  10. dickster27
    dickster27
    from Texas
    You can get those teardrop shaped scoops from CW Moss or SO-Cal. But Moss is less expensive.
  11. scootermcrad
    scootermcrad
    Todd553... still wondering about this linkage. It's awesome!
    Anyone else know anything about this linkage?
  12. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    Great thread. Probably the most popular 6x2 set up for the Sbc is the Edelbrock X-1 cross ram. I know that is what I originally wanted but could either not find or when they did come up I did not have the extra money.. so I settled. Now for the most rare (that I have seen) is the Edelbrock removal top crossram 6x2. I have drooled over this one for awhile, almost bought it once but my common sense guy (on my left shoulder) won out
    Mine set up (and if I may say so, nicely detailed)
    super rare removal top cross ram set up ST 10-6
    dana barlow likes this.
  13. Dreddybear
    Dreddybear
    Bringing a great thread with good pics back up. Enjoy.
  14. scootermcrad
    scootermcrad
    Still want to know about THIS LINKAGE! TODD!!!!!
    It's beautiful!
    Anyone else know anything about it?
  15. glorydays123
    glorydays123
    from dallas
    i'd like to find those stacks...
  16. Jmountainjr
    Jmountainjr
    beatnik shows you a nice picture of a 3924 for three bolt carbs. They also come drilled for 4 bolt carbs. I'm currently putting one together with six holley 94s for my 377 chevy. It a good manifold and has good balance tubes. The one downfall is that without carb spacers, the low profile requires all the carb linkage arms to point up - and any progressive linkage that I've seen has a very hard push to it due to no mechanical advantage. So, I'm running mine straight up and starting with the two center carbs blocked off. And if anyone said that running 4 or 6 carbs is easy - well they lied. Well worth it, but it is a lot of work. In your case, I'd also look at your cfm needs. The typical 3 bolt carb flows 150-170 cfm each. If you really are building a monster small block, and if you want progressive linkage, you may be better off with a 4 bolt manifold and a six pack of Rochesters. Just my thoughts.
  17. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Jimmy Shine made that set-up...............He made the bronze looking pieces out of wood, then had them cast, then machined them..........works great, Littleman
  18. J.D.
    J.D.
    from Clovis, CA
    Here is some bad pictures of my Offenhauser
  19. scootermcrad
    scootermcrad
    GREAT! Finally! Somebody answered me! LOL! I've been thinkin' about those for a long time! Thank you sir! :)
    Wow! Incredible looking!
  20. 38pickup
    38pickup
    Here is my 6x2 setup. I am running an offy intake with 6 94s... All of the work, there are no block off plates there boys. Its running most of the time on the center two then goes to the back set then the front pair open. All of the lines are hand bent.
    The linkage is an eelco, that has been modified to work. I am using the original spoon type pedal with it all. Also I have working chokes not to many guys have chokes. The reason for the chokes is because the motor itself does not like running cold. I guess that comes from it being a ex-blower motor.
    I run on the street and have no problems, it just works. When you want to open all 6 carbs you know it. And when you do look out becuase she is pulling like a south bound frieght. If you want anymore technical questions, let me know I will be more then happy to answer them.
  21. arkracing
    arkracing
    Any idea how this set up ran on the street? The linkage is Awesome, but I'm also curious as to how it runs.
    Any comments either Dave or the owner Todd?
  22. scootermcrad
    scootermcrad
    Very clean setup!
    What are those fuel dist. blocks you're running? I like those!
  23. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    From what I was told, Todd's 327 was tuned on the dyno, and whom ever built the carbs and tuned it..............is righteous and did a great job, that small block is brutal...............What little I rode in the car, it did great and was fun to ride in..............you just have to hang on...........but Todd knows way more about the car than I..........Littleman
  24. scootermcrad
    scootermcrad
    Todd! Where are you!? I haven't talked to you since the pub during SEMA in Vegas, I think! You just dissappeared into thin air!
  25. Ratherman
    Ratherman
    from WI
    Here are two of our cars - the 4x2 on the flathead run straight-on; as will the 8x2 on the hemi...it just takes a little patience :D
  26. scootermcrad
    scootermcrad
    Sorry to go off on a tangent here... but what are you going to do for water provisions with the Hemi and the 8x2 offy? Looks like a 331, but hard to tell with the shadow over the front of the heads. Didn't see any water ports out the front.
  27. 38pickup
    38pickup
    They are from speedway and have no markings. I think they are very close to offenhauser's. Hope this helps.
  28. Ratherman
    Ratherman
    from WI
    It is a late '55 331 - so it has the water ports on the front of the heads. We are going to use a standard 354/392 water cross-over. Very little room for even a Chevy waterpump - so it will probably end up being electric...
  29. jawdrpn36
    jawdrpn36
    from bay area
    here is my setup with fuel line changed[​IMG]
