6x2 Carb Set Ups - Pics and Information?? - who made them?
Discussion in 'The Hokey Ass Message Board' started by arkracing, Aug 1, 2006.
  1. scootermcrad
    scootermcrad
    Okay, that's what I wondered... couldn't tell if there was something lurking in the shadows there or now. This is what I'm going to do with my Offy 6x2 also. Thanks!
    Thanks! Nice and clean. That's what I like about them.
  2. BTT There was an article somewhere about tuning 6x2 setups, and cam choices. I was planning on running a 365 H.P. solid lifter in my .030 over 350, camel hump or power pack heads, and flat top pistons, with 6 94s.
  3. scootermcrad
    scootermcrad
    Let's bump this one back up. Great thread!
    Anyone have pics of a straight, non-progressive 6x2 linkage? Only saw one in there that wasn't a progressive setup.
  4. Littleman has a straight 6x2.
  5. scootermcrad
    scootermcrad
    That's right! I remember him saying that now. I'll see if I can dig up the pics.
  6. scootermcrad
    scootermcrad
    Here's a straight linkage setup on a 8x2
  7. Clutched
    Clutched
    Back to the Top...how about more tech...more opinions, to run power valves? to not run power valves...what size jets. straight linkage> engine combos lets hear it from expirence this is a good thread.
  8. LOST ANGEL
    LOST ANGEL
    Does anybody have a setup with carbs other than Strombergs?-MIKE
  9. Circus Bear
    Circus Bear
    Here's mine. It's a rare edelbrock intake for Big Block Mopars. It came with 6 Rochesters. That's a bit of overkill so I have 94's on there now. The coolest thing about this intake it that it's drilled for 4 bolt and 3 bolt carbs, and since it's 3 logs connected with rubber tube it will fit all BBM's from the 1 year only 350 to a 440. It's on a 383/727/3.55 suregrip setup that's in my '47 dodge coupe.
  10. strombergs97
    strombergs97
    Hello..does anyone know where I can get a 8x2 Intake for a 392..
    thanks
    Duane.
  11. FunnyCar65
    FunnyCar65
    from Colorado
    That's a cool set up,I just picked a Drag Star for a BB Mopar.
  12. Nekronomicon
    Nekronomicon
    Nice work there, what have you done to the carbs?? They look shiney
  13. ranfor
    ranfor
    has any one tryed to do a efi on one of these manifolds yet ??
    sincerly ranfor
  14. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    here's my 97's
  15. I Like Cars
    I Like Cars
    from England
    To keep the thread going here's mine. Hopefully will be fitted in the near future.
      42.5 KB
  16. tommy
    tommy
    This is EFI. The injectors, fuel rail and wiring are in the valley plugged into the bottom of the log manifold. The fuel pressure regulator is right behind the thermo. housing and the TPS is connected to the rear of the linkage. This is not mine. I just noticed it and talked to the owner who didn't know too much about it either. A pro shop was doing it for him.
  17. Tech @ BG
    Tech @ BG
    Here's a pic of our new set up using our AeroRam intake. 6 Demon 98's for the SBC , SBF soon to be released and working on a 8 carb version for the BBC.
  18. moparforlife
    moparforlife
    from Rolla, MO
  19. Circus Bear
    Circus Bear
    Great pic.
  20. 33_chevy
    33_chevy
    from TX
    Just wanted to keep this thread going,looks like some nice setups,i need all the pic's of linkages i can get,i am building mine right now.So send some more pic's..
  21. 33_chevy
    33_chevy
    from TX
    Redone my linkage...
      498.7 KB
      419.2 KB
  22. Pooch
    Pooch
    from Oklahoma
    This one is mine. No linkage yet but Im workin on it.
  23. here is mine been driving this since the 70's
  24. the fuel line is next on my list to do it in steel
    i get 13.6 MPG in town 16 if i am easy on it
    no power valves home made linkage
    had Aeroquip but Obama fuel ate it up
  25. Hot Rod Michelle
    Hot Rod Michelle
    What 6 log or 6x2 intake is recomended for a 330 DeSoto Hemi?
  26. 33_chevy
    33_chevy
    from TX
    jandlcars,,did you use any vacuum off this intake?if so where did you get it from and what did you use it for..i am running into issues on mine right now and i need vacuum for brake booster and modulator for ******
  27. 33_chevy
    33_chevy
    from TX
