7.50x16s...
Discussion in 'The Hokey Ass Message Board' started by flatout51, Jan 31, 2011.
  1. flatout51
    flatout51
    Im wanting to run 7.50 16s on my project but i need to know the actual dimensions of the tires. I looked on Cokers site but the tires i get from there are never the sizes they claim them to be. Need height and over all width. I tried a search but couldnt find this and i know plenty of you guys are running them. Thanks David
  2. Dirty Dug
    Dirty Dug
    7.50X16 Deluxe Champions are 31" high and 8" wide on 5" wide wheels. So the width will vary depending your rear wheel width... Hope that helps.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    ^^^what he said^^^
    kidcampbell71 likes this.
  4. flatout51
    flatout51
    Awesome! I have 5" wide wheels.. This helps a ton! Thanks!
  5. gimpyshotrods
    gimpyshotrods
    There will be some variance from brand-to-brand, as well. Best to plan for that too. It wont be a ton, but I have seen 1/4" to 3/8".
  6. flatout51
    flatout51
    Im building a 29 Tudor sedan hiboy on deuce rails. I want the stance of Brian B***'s hemi coupe and im trying to calculate my rearend width. Anybody have an idea what rearend width i need? Or someone who would?
  7. flatout51
    flatout51
    I have a truck 9 inch that measures 61.5 inches... i think it will work great... but im bad at math! HAHA!
  8. flatout51
    flatout51
    How much wider is a sedan than a coupe? B*** runs a bronco rear and its only 58 inches! And he has tons of body clearence.
  9. flatout51
    flatout51
    my wheels are stock ford f100 16x5" wheels Offset should be damn close to center or neutral offset if im not mistaken...
  10. flatout51
    flatout51
    Measured my body and right above the wheel well indent and it is 52.5 inches. The widest part of ther tire will be well below thatso i should have even more clearence. worst case ill need a small spacer...
  11. LowA100
    LowA100
    Heres what the height looks like!
  12. flatout51
    flatout51
    Beautiful car!!! Those tires are pretty big... but perfect! Should get my deuce rails Monday Or Tuesday! Then the madness begins!!!
