Anyone take a 7" brake booster apart? I have one where the master cylinder, when bolted on, is not level with the mounting bolts of the booster. The master is about 15 degrees from being level. Any help would be greatly appreciated.
They are made of stamped sheet metal. It could just be bent. Bolt on the master, and bend it back. You may have to push a little past square, to get it to square, when it springs back.
