7 Degree or 10 degree?
Discussion in 'The Hokey Ass Message Board' started by 35WINDOW, Aug 12, 2005.
  1. 35WINDOW
    35WINDOW
    Fellas,
    I am trying to understand the difference (beyond the obvious) as to why they offer 7 degree and 10 degree valve locks. Anybody out there know?
  2. Steve
    Steve
    to confuse you?? just make sure you use the right ones for the valve retainers
  3. 35WINDOW
    35WINDOW
    Steve,
    thanks, but I am trying to understand why they are made. Is one better than the other? Is one made more for racing, or better for R.P.M.?
  4. JOECOOL
    JOECOOL
    Yes they are more for high RPM engines. The wedge factor , or what ever you want to call it, is greater and there fore they won't come loose as easy with valve float, monster springs. . Most 10 degrees locks and retainers are made of a better quality stock than the 7's.
    If you are using a street type cam with the correct springs they aren't required.
    But if your going to buy new ones anyway ,and the deal is close go-ahead.
    Just make sure the retainers match the lock.
  5. suedesled
    suedesled
    It is my understanding that the 10 degree is a better lock due to the increased surface area and the distribution of the spring pressure. In high RPM situations the are less likely to pull through the retainer but this is under severe cir***stances.
  6. beatnik
    beatnik
    7 degree is what most engines use stock, it's the standard.
    10 degree is suppose to give more clamping force, because of more surface area and are used with higher valve spring pressures.
    You guys beet me too it.
  7. krooser
    krooser
    Kinda like like octane...more must be better...
