Technical 700r4 kickdown 26 roadster
Discussion in 'The Hokey Ass Message Board' started by nailheadjay, Jan 23, 2015.
  1. nailheadjay
    nailheadjay
    ok. latest dilemma .. in the roadster the auto kickdown...the cable gets hooked to the carb linkage..i****ume at the bottom hole on a new edelbrock.. at throttle down "car at idle i should say" what if any slack should there be in the that cable?
  2. Ralphies54
    Ralphies54
    Because a 700 was a fuel injection car or truck******* you will need a special correction adapter to your carb. I don't know which one's but somebody will jump in here to help you out. The cable should be fully extended at full throttle or better yet set up with pressure gages. Good luck Ralphie
  3. RICH B
    RICH B
    The cable on a 700R4 is more than a kick-down cable. It is a TV (throttle valve) cable and it controls internal pressure in the trans and both the geometry of travel and adjustment are critical or you can trash the trans. Should be a special arm available for the Edelbrock to accomplish that.
    And looks like somebody else typed the answer quicker than me; but remember there is more to it than full stroke at WOT.
  4. Ralphies54
    Ralphies54
    By the way Jay, that's not a" kickdown" all shifting is done with pressure.
  5. nailheadjay
    nailheadjay
    ok.. thanx guys!!
  6. Kiwi 4d
    Kiwi 4d
    Have a peek at bowtie over drives site , everything you need to know pretty much.
    Cheesehauler likes this.
  7. nailheadjay
    nailheadjay
    yeah i checked it out.. very helpful... a little more complicated than doing it on my 65 riv but easy enough.. thanks
  8. 48ford
    48ford
    Jegs sells the adaptor you need,it's there own line. If you can't find it on line give them a call
  9. 48ford
    48ford
    Look. Up purple sage trading post, school down to summers page he has a good read on geometry
  10. OLDSMAN
    OLDSMAN
    Go by the info on Bowtie overdrive. If you follow their instructions you willhave the TV pressure right. This is a very critical adjustment on the 700R4 transmission
  11. flux capacitor
    flux capacitor
    As a teen, I fried a 700r in my 83 gmc step side when I swapped a big block in place of a 250 6cyl , on first babied test drive all because TV cable wasn't fully opening ! After that I know how, a CA1970 pioneer 700r4 adjustable cable can often be of help. Be careful! Flux
